fe verses nitro
  • boatinjoe
    • 50
    fe verses nitro
    will /can the stilletto be competitive against nitro opc's 3.5 thats all thats around here to race, I figure if I can win a few races it might open up some eyes. I am sure they will let me run with them. just wondering .. joe
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    You may have to change the OB to an O.S. or something like it
    • ron1950
      • 3024
      what kind of speeds do the nitro boats do? with a little work this boat could do 45 or so.....maybe more but heat is a problem sometimes,,,,,
      • Diegoboy
        Administrator
        • Mar 2007
        • 7247
        Not sure on the speeds, but they are pretty fast.
        • Darin Jordan
          • 8332
          No, You won't...!!
          The outboard will be just fine. With the stock motor, and a decent setup, you should be able to run with most of the 3.5 Stock boats.
          Darin E. Jordan - Renton, WA
          • Diegoboy
            Administrator
            • Mar 2007
            • 7247
            Sorry Darin, I was not thinking "spec"
              • 7990
              The biggest advantage with an FE OB versus a nitro OB seems to be reliability. Over a multi-heat race the FE boat will likely compile more points than most of the nitro boats, even if it isn't as fast. But then some ARE as fast or a bit faster than the nitro tunnels. You just don't have to be faster to do well.
              • Darin Jordan
                • 8332
                No worries... But either way, you shouldn't need to replace the OB, even to upgrade to a hotter motor. It'll handle it!
                I'd do the performance mods mentioned in my Stiletto race prep thread. Should be nearly bullet-proof then. Biggest improvements would be to get a Hyperformance Bullet-Drive stubshaft and flexcable from Steven, and then properly fit the flex. After that, I see no reason why this OB can't be a race OB. You'll be paying a slight weight penalty, but not enough to justify a completely new setup.
                All just in my opinion, of course...
                • Darin Jordan
                  • 8332
                  I prove that every time I hit the water!!
                  Hahahaha....
                  • Diegoboy
                    Administrator
                    • Mar 2007
                    • 7247
                    Have you posted a pic of the bottom of your boat after the block sanding?
                    • Darin Jordan
                      • 8332
                      I thought I did. I'm a little behind on posting pics. I have some that show some of the prepping I've done, but have been busy with other things and haven't posted them yet.
                      Our main race season ends this weekend. After that, it will be mostly building time, so hopefully I can get caught up.
                      • ALD
                        • 96
                        Darin,
                        hpi-3.5-bullet-drive
                        Hyper Performance 3.5 Bullet Outboard drive, steering linkage and motor fit new drive?
                        • Darin Jordan
                          • 8332
                          Originally posted by ALD View Post
                          Darin,
                          I'm talking about just replacing the stub shaft and flex cable... Mostly the stub. I like the aftermarket flex cables because the flat section is shorter, allowing the cable to arch more coming into the squaredrives. The Hyperformance stub is simply awesome and will last forever.
                          • ALD
                            • 96
                            Stubshaft same as prop shaft- I'm not sure? Thanks.
                            • Darin Jordan
                              • 8332
                              Yes... prop shaft. Just like a stock K&B, the stock Stiletto stub will get loose after a bit of running.
