fiber glass help
  • kinsei
    • 8
    fiber glass help
    hi all i got my boat (not from ose btw), but there is a long crack between upper and lower hull in the front
    how should i repair this? thanks in advance
  • JimClark
    • 5913
    send it back
    Billy Graham
    • kinsei
      • 8
      thanks but thats the problem... as i am from hongkong sending it back will cost me another 90USD!
      any easy and sure way to do this??
      • westbeach
        OSE Rocks!
        • 969
        Is the hull fiberglass with gelcoat finish?
        HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
        • domwilson
          • 4411
          I would contact the seller to see if they might pay shipping as well. Send them a pic of the damage. Many sellers will work with a customer.
          If they won't work with you, then simple epoxy should fix this.
          Government Moto:
          • kinsei
            • 8
            sorry this is my first ever fiber boat.. and the seller told me to contact horizon
            westbeach: gelcoat do you mean the thing that fallen off the cab?
            dom: simple epoxy do you mean the thing that held the screw ring? can you give more detail?
            • Flying Scotsman
              Fast Electric Adict!
              • 5195
              It is a fibreglass hull with a paint finish, was the box damaged when you received it. The dude you purchased it from is MIA. Use a two part epoxy 30 minutes or longer to fix it
              Douggie
              • kinsei
                • 8
                here the pics, the box arrived rather intact at all sides which makes me feel that this boat do suffer from some build quality problem
                • andym
                  More Go Than Show Prop Co
                  • 2454
                  Come on D.Jordan send him a hull..................................This is were we all say BUY FROM OSE, sorry about that. Two ways to fix, easy way see if you can part it 1-2mm and use epoxy as stated above. If you use micro balloons it will even be white! Or use fiberglass resin and hardener the same way. Epoxy is easier and widely available just use a good one.
                  • westbeach
                    OSE Rocks!
                    • 969
                    Epoxy or autobody filler works well, just make sure you sand the area of the chip a little more to get some good adheasion.
                    • ron1950
                      • 3082
                      darin in another post says it is just painted fiberglass
                      • GP73
                        • 546
                        WOW. Just... WOW.
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          Did you run it? or did you buy it used? I see rust in that second pic.
                          • ron1950
                            • 3082
                            looks as if it spent alot of time on the ocean in shipping i hate rust
                            • kinsei
                              • 8
                              its new, shipped by EMS
                              i havent run nor fixed it yet. i have grabbed 2 brands of epoxy to try it out but i found its quite difficult to open some gap for filling without making it worse..!
                              for the rust, yes, but how come? its should be lot easier to fix than the crack with WD40 tho
                              side note: i didnt get any single reponse from horizon so far
