Stiletto Race Prep
This is a sticky topic.
  • johnf
    • Dec 2009
    • 1086
    Good stuff Darin. Glad you got those designs in line.
    Catching Air!
    • rchippie
      • Jan 2010
      • 640
      Darin What is the width & height of the battery box ?. Will the Turnigy 4s 5000 lipos fit. http://hobbycity.com/hobbyking/store..._40C_Lipo_Pack
      • Darin Jordan
        • 9446
        Yup... I don't see why not. I think I mentioned above that I tried it with a ThunderPower 50C 5200 mah HardCase 4S1P pack yesterday and it fits in with room to spare... Balances correctly as well. Quite a bit of room in the battery area.
        If one wanted to substitute an aftermarket ESC for the stock one, then the shelf the ESC sits on could also be removed, (lay the ESC on the batteries or something) and I think one could fit TWO 4S packs in there, though I have no idea why you would want to do that...
        Darin E. Jordan - Renton, WA
        • rchippie
          • Jan 2010
          • 640
          Thats great i just wanted to make sure . Because the Turnigy 5000s are so wide compared to other lipos.
          • Darin Jordan
            • 9446
            The ThunderPower pack is 45.2H x 46.5W x 138L... And there is still room above the pack. The Turnigy is 49H x 37W x 149L, so I think it should fit. Can always lay it on it's side.
            • BakedMopar
              No Mo Slipah
              • Sep 2009
              • 1743
              This one is beautiful Darin. I think I may just get one. Would be my first tunnel.
              • Grimracer
                • 660
                Darin,
                The boat looks great.. great job!
                take care brother..
                Grimracer
                • electric
                  • 1973
                  Looking at the picture, I am wondering whether those turnigy's will indeed fit. Mainly because the turnigy's have those big honking wires that feed out of the side which impedes the side to side width. I can barely squeeze them into a UL1 for the same reason.
                  I will break out the batteries(and account for the side wiring) with the ruler tonight and see or like Darin said you can lay them on their side.
                  Congrats on the Boat Darin!
                  • 6S HYDRO
                    • 1325
                    Darin i thought on your personel tests that the bj26 motor a36561500 really was around 1800kv, so is this new 1800kv version in this new boat really just the same thing?
                    • Darin Jordan
                      • 9446
                      Nope... the BJ motor tests around 1625-1650 actual KV. The SV27 around 1525-1550KV... I haven't tested this new one for actual KV, but it's a new wind, and should be 1800KV or more. I'll try to setup my test bench again one of these days to get the actual numbers... It's definitely a new motor wind. I had them annodize it and the ESC a different color so they'd be easier to differentiate.
                      electric - The internal dimensions of the battery tray (Width and Height) are 2 3/8" and 2 3/8". There is right at 1" between the bottom of the tray and the bottom of the ESC platform as well. A 2S pack or a 6-cell NiMH pack will slide up under there...
                      • 6S HYDRO
                        • 1325
                        im almost positive you said it was at 1799 or somthing around that for the orig. bj
                        • Steven Vaccaro
                          Administrator
                          • 8932
                          Here is his chart.
                          Steven Vaccaro
                          • AndyKunz
                            • Sep 2008
                            • 1443
                            The BJ is a low-RPM motor, much lower than the AC one.
                            Darin may have said he WANTED an 1800Kv motor. I know we had lots of e-mails going back and forth to get the 1800 he wanted in this one.
                            Andy
                            Spektrum Development Team
                            • 6S HYDRO
                              • 1325
                              well i was pretty close, on extreme timing
                              • Shane_744
                                Choppin' it up
                                • Sep 2009
                                • 108
                                Great information and great write up on the new boat.
                                How does it feel to have your name and picture on the box!?!
                                TEAM Crawler Innovations, TEAM Holmes Hobbies, TEAM BC Paints!, TEAM OTTSIX , TEAM Y-Town Crawlers
