Having some issues with my Mystic 29
    • 5660
    Originally posted by agentorange View Post
    Tiqueman- Yes it is a proboat 1800kv. Its seems to rotate normally when I have it on the bench. It has a pop to it when you spin it by hand.
    Lenny- I just greased the shaft and it slides in perfect and goes into the coupler fine with little to no force applied.
    tlandauer- I will have to wait till Monday to hit the store up but I thing I am going to try the 5.5 plugs out. It might be like Tiqueman says it could be the motor is on its way out. if so well I have a 2200kv Leopard that needs a new home so we will see what happens.
    That is why I said to keep an eye on the temp of that motor, I also had a hunch that the motor is having issues.
    Like Tiquerman says my MG has the Leopard 2200kv with the Seaking 180 ESC, been two years and knock on wood, I have no problem so far other than an extended 7 or 8 min. run which resulted some bulged capacitors on the ESC. I replaced them with the addition of a cap bank.
    • TheShaughnessy
      • 1419
      A x642 shouldn't be taking out a PB 1800 I've seen them pushed much further. I am
