New system installed!
  • Megabiker98
    • Jan 2013
    • 253
    #76
    I'm gonna use the strongest stuff I can find! Hahahahaha, even then on the first run I'm gonna be bringing it in as it will be my first time using the boat on a longer wide open run, so this will be added to the list of frequent checks every time it's brought in! Lol
      All the best. Hopefully you don't lose that prop!
      • Megabiker98
        • Jan 2013
        • 253
        #78
        Ya, I'm super nervous cause I DON'T not want to loose it!! If I do, hopefully the divers that have been there the last 2 years will be there this time and can help me out!!! 😂
        • Megabiker98
          • Jan 2013
          • 253
          #79
          Ran it a couple times this weekend, about 4 times or so ROUGHLY, the first time I ran it, I had the strut set to where u guys told me at first, and I am not positive but I think that was to much of an adjustment as it was pushing into the air a lot, but the wind was blowing into it also, flipped it 2 times the first run. Brought it in after the 2nd flip cause I was scared to death after that! Hahaha, 2nd run I decided to lower the strut to level with the sponsons, and ran it like that and it ran quite a bit better! Wouldn't say it was great but it was definently good! Wasn't flipping, and when it did start to get light on its heels I let out and it came down. The next couple runs ran exactly the same, and I was gonna run it this morning before we left and get some vid for u guys but I THINK the charger overheated or something. It stopped working and I only had 1 battery charged up so I couldn't get any video of it running! Flex shaft stayed in place this time moved MAYBE a mm at most and the prop didn't come loose it stayed on there good! And also if anyone has had the same experience with the over heating charger let me know what I should check. I have a thunder ac680 charger!
          • Megabiker98
            • Jan 2013
            • 253
            #80
            So I ran it a couple more times today, at strut level with sponsons, ran it with this setup about 3-4 times, and it was still a little light as flipped a couple times. But it was windy, so the day came when the water was glass, and I ran it then and it still did the same thing, so I decided to make a change knowing that it wasn't setup properly yet, so I moved the batteries about an 1 inch forward ran it in slight chop/wind and it ran a little better so hopefully I can find out more next time I'm out!
            • Megabiker98
              • Jan 2013
              • 253
              #81
              Ouch, so loctite definently does work. I am currently taking the prop off as I got a new one from kintecracing, and boy is that but on there GOOD!!!! It's giving me a little trouble!!!! Hahaha
                If you use a little heat on the nut it will come off a little easier for you,
                Just try not to heat anything else up.
                Use some foil as a barrier to black the heat from things.
