Ride pads and blue printing???
  • Megabiker98
    • Jan 2013
    • 253
    What's all the talk about blue printing the ride pads?? What does it to for performance? If someone is willing to take time and link me to somewhere that explains a step by step to do it or a video, that would be greatly appreciated!
  • Heaving Earth
    • 1929
    I'm pretty sure blue printing is making the ride pads flat if I'm not mistaken, by using bondo or such.
    • JimClark
      • 5913
      look for the Race prep post in the Geico forum by Darin Jordan same hull as the mystic
      Billy Graham
      • Megabiker98
        • Jan 2013
        • 253
        Ok where could I get body filler from? My local ace hardware has body filler but it has METAL adhesives? Will that still work? Or do I need some sort of fiberglass adhesive stuff?
        • JimClark
          • 5913
          auto paint store
          Billy Graham
          • Heaving Earth
            • 1929
            Does your hull need it?
            • Megabiker98
              • Jan 2013
              • 253
              I don't know I got to thinking about it and thought it wasn't worth it cause after digging a little deeper, it sounds like it is only gonna benefit u in a racing atmosphere, and I'm only gonna be running it around for fun
              • martin
                • 2881
                When you fill the pads your getting rid of hollows that hold the hull down & affect performance, you also need to make sure all the edges (side & rear edges)of the ride pads are nice & sharpe without any radius on them.
                • G-UNIT
                  • 971
                  Walmart carries bondo kits, use the light weight stuff, not the kind that has fg in it because its just to hard to sand for our applacation, just my two cents worth, I tryed it and it's a pain to sand, but the light weight is no problem.
                  • martin
                    • 2881
                    Just use auto body filler paste that dosnt have any fibre glass in it. It drys fast & is easy to sand, some even says easy sand on the tin.
                    • rodneypierce
                      • Oct 2011
                      • 19
                      if your going to blue print, before you fill anything, might want to actually sand the ride pads first and see if you can get the dips out that way....
                      • Darin Jordan
                        • 9446
                        On several of the MG/Mystic hulls I've done, a simple block sanding reveled the low spots and helped to get things close. One pass with some decent filler (I use Feather Fill lightweight body filler), then some touchup got me most of the way there. A heavy-build primer can help with the finishing up also.
                        Is all this necessary?? No... Will it dramatically improve the performance of the boat?? That depends on what you expect from it. It's not the one answer to perfecting this package, but it's a solid component of it.
                        My Race Prep thread shows clearly how to perform all of this.
                        Darin E. Jordan - Renton, WA
                        • rodneypierce
                          • Oct 2011
                          • 19
                          Well stated Darin!
