Replacement Propeller strut for Proboat Mystic
  • Garrett
    • Mar 2012
    • 140
    My bushings are gone, and the strut is coming apart. Which replacement should I get? I was looking at these two: http://www.offshoreelectrics.com/pro...rod=oct-struts and http://www.offshoreelectrics.com/pro...prod=ose-80975
    The OEM is Back ordered till February 2013. and I'd like to not be outta the water that long. any help is appreciated. Thanks
  • Heaving Earth
    • 1929
    How on earth does a strut come apart?
    • Heaving Earth
      • 1929
      Maybe post a wtb thread. Someone might have a spare. Honestly neither of those look great for your boat
      • MAMBA2200
        I need a scooby snack
        • 1347
        I put a speedmaster. 21 strut on mine just a few minor mods are needed its almost a direct replacement
        Sent from my DROID RAZR using Tapatalk 2
        • Garrett
          • Mar 2012
          • 140
          Did you go with the round or flat strut? and was it the mono or hydro?
          how much mod work did you do?
          • MAMBA2200
            • 1347
            i used the round mono as for the mods it was just making the mounting bracket fit think i had to spread it a little is all
            • Darin Jordan
              • 9446
              That's the route I'd take as well....
              OR....
              I put one of these on my Miss Geico that I ran at the 2012 Nats, and it worked really well...
              http://www.ebay.com/itm/Adjustable-s...item20c34723c4
              Cornering was amazing. I ended up trimming down the skag a bit to free up the boat for the setup I was running, but otherwise, the strut is a nice piece, and fits well... I did have to open up the forward end slightly to fit over the factory stuffing tube.
              Darin E. Jordan - Renton, WA
              • Garrett
                • Mar 2012
                • 140
                Thanks guys, I kinda like that skeg. Here's the problem that I've encountered, prop strut.jpg and here's the boat: red whit cracker mystic.jpg
                Darin what do you mean open up the forward end? like with a drill bit or reamer?
                • Darin Jordan
                  • 9446
                  Originally posted by Garrett View Post
                  Thanks guys, I kinda like that skeg. Here's the problem that I've encountered, [ATTACH=CONFIG]91358[/ATTACH] and here's the boat: [ATTACH=CONFIG]91359[/ATTACH]
                  It looks like something must be out of balance or otherwise not spinning true. I've been running this hardware since the very first MG entered the country, and have never had one come apart like that. Check your driveline for trueness, and make sure the prop is balanced. I suspect you'll find that prop nut is adding to the problem.
                  I don't recall exactly what I had to do... it's been awhile, but I remember having to make a mod of some kind to get the stuffing tube to fit correctly. I believe I had to open up the forward end of the strut a tad (the cone piece). Sorry, I don't remember the exact details. I might have actually fitted the stock nose-cone piece to the new strut... Again, sorry, I just don't recall at the moment...
                  • Garrett
                    • Mar 2012
                    • 140
                    Darin, do you have a picture handy, that I can see what you're describing?
                    • Darin Jordan
                      • 9446
                      Sorry, I don't... the boat is packed away and I don't think I put any pics of the new strut online...
                      • MORIDE
                        • 108
                        Strut
                        This looks pretty nice, but is the strut on backwards in the pics?
                        • bob_t
                          • 159
                          sure looks like it is backwards ... blunt end leading, sharp end trailing ...
                          Or ... maybe they just drive it in "reverse" all the time
                          • Darin Jordan
                            • 9446
                            That's the one I have on my MG, and it's a nice quality piece. The skag is too long for the application. IT works very well, but you lose a lot of speed when you turn the rudder. I ground mine down to about 1/4" long. Otherwise, it is a truely nice piece for this application. You can open up the holes in your existing strut mounts so they can be slid outward slightly, and then this wider strut will fit between them.
                            You will likely have to modify the side of the leading end opening to fit the factory stuffing tube.
                            Go for it!
                            • MORIDE
                              • 108
                              Question
                              These things are so much fun, I know how we all like to modify them, but what is the advantage of this over the stock setup?
