proboat 1800kv
  • wht73
    • Feb 2012
    • 113
    proboat 1800kv
    Is this a 6 pole motor and if so what timing should it be set at?
    can this motor handle 6s?
  • Diesel6401
    Memento Vivere
    • 4391
    Yes its a 6pole, but more importantly its a "y" wind. Timing should be 7.5 - 15 although I would think 11.25 would be best. That's on a seaking esc, swordfish escs med timing should be just fine.
    Change the motor/esc connectors to 5.5mm bullets the stock 3.5s wouldn't work, make sure your not using deans plugs 5.5mm or ec5 connectors. I'm personally NOT a fan of 1800kv motors and 6s, unloaded rpms are outside my comfort zone although being a 6 pole helps. Prop small, keep the runs limited to a few wot passes and keep in mind if it blows its your fault not a PB issue. Lot of guys run the motors way past what is recommended and get an attitude of something bad happens which isn't cool... in my book at least.
    Sent from my T-Mobile G2 using Tapatalk 2
    - Diesel's Youtube
    - Diesel's Fleet
    • wht73
      • Feb 2012
      • 113
      Yeah it's a 180 hobbywing and I set it to 11.25. It already has 5.5mm bullets on it so that's done. I might just get 5s packs for it or more 7.4 with more ahr's.
      There is a lot of room in there! (Mystic)
      • Diesel6401
        Memento Vivere
        • 4391
        If you already have 2s lipos just get some 3s lipos same brand, mah and c rating as your 2s packs and run 5s.
        - Diesel's Youtube
        - Diesel's Fleet
        • wht73
          • Feb 2012
          • 113
          Thats ok to do? Which battery ends up with the positive lead to esc?
          • wht73
            • Feb 2012
            • 113
            Can this motor spin a x442 prop? I just ran it w/ 2p, 4s pacs and clocked 38.8mph with stock mtr and prop. 4s bats are to big though. Make the boat heavy also.
            • Diesel6401
              Memento Vivere
              • 4391
              Yup perfectly fine to do. Doesn't matter which lead ends where. Just make sure your wiring in series and not parallel.
              - Diesel's Youtube
              - Diesel's Fleet
              • Diesel6401
                Memento Vivere
                • 4391
                Should spin just fine on 4s. Just drop down to 4s and not 4s2p. At speeds on stock motor on 4s your just carrying extra weight around.
                - Diesel's Youtube
                - Diesel's Fleet
                • wht73
                  • Feb 2012
                  • 113
                  Yeah they are to bulky.
