Proboat Mystic Modifications and Setups
  • mtbenjamin77
    • 885
    I am building a custom PB mystic for a friend. I'm not familiar with this boat and was womdering were my CG should be set. I know these boats have bounce problems if not built correctly and I want to avoid any potential issues. It will be setup with a 4074 on 4S. Any help is greatly appreciated.
  • mtbenjamin77
    • 885
    As of now I'm waiting for the motor, esc and a few other items to arrive. I really need some advice on setting up the CG on these hulls. here's some photos of what I have so far.
    2012-06-02_01-01-18_31.jpg2012-06-02_01-01-24_998.jpg2012-06-02_01-01-36_489.jpg2012-06-02_01-01-54_445.jpg2012-06-05_14-41-01_83.jpg
    • stadiumyamaha
      • 1371
      If its the same as the geico which it should be then the cg is at about 30% from the transom. 9-10 inches.
      • mtbenjamin77
        • 885
        That's HH suggestion with the stock setup. That should apply no matter what the setup is. I see you run a geico on 2200kv is that the PB? And are you using the same CG setup? I'm trying to find the best location for the battery trays so that the batts can be moved around to achieve the best performance based on water conditions. I've seen some guys adding to the stock battery trays so they can move the batts all the way back. I don't wanna set mine up to far forward if that's the case.
        • mtbenjamin77
          • 885
          Add a few more pics....................
          2012-06-06_03-22-22_272.jpg2012-06-06_03-22-29_164.jpg2012-06-06_03-22-44_611.jpg2012-06-06_03-22-57_770.jpg
          • JimClark
            • 5913
            I might suggest looking thru the many setup threads where all this has been talked about numerous times.
            Billy Graham
            • mtbenjamin77
              • 885
              Jim,
              Thanks. I've tried a search but my forum skills are limited. didn't find much. I'll try again. I know I'm not the first to build one of these.
              • mtbenjamin77
                • 885
                Jim can you suggest any keywords for my search? I made a very specific search but came up with tons of matches but nothing really addressing this issue. Any help is greatly appreciated.
                • mtbenjamin77
                  • 885
                  or maybe a link?
                  • larz001
                    • 150
                    mtbenjamin77, how did you get the stock plywood out of the hull, ive been looking at mine and dont know where to start, whatever pb used to fasten the pieces together looks brutal to remove, any assistance you could give would be apreciated
                    proboat mystic, preditator outrigger, tt desparado jr, vac-u-vee jr, aqua craft top speed v2, dumas 1/8 scale hydro
                    • mtbenjamin77
                      • 885
                      Use a pair of pliers and work the pieces back and forth. Then use some coarse grit sand paper to smooth out the leftovers
                      • larz001
                        • 150
                        im gonna guess everything is going to come out in broken pieces
