what motor
  • dana
    • Mar 2010
    • 3660
    Ul1 motors are great, but not for 5 and 6s. To run that number of cells you need to be between 1500 and 1800kv
    • HondaHead
      • Mar 2012
      • 15
      Thanks a lot,just trying to get a good solid set-up,boat handles good and plenty fAst on 5 cell
      With spartan prop,now it needs to go faster
      • dana
        • Mar 2010
        • 3660
        keep in mind, jumping up 1s in your packs is a big difference on the motor. a motor that might be perfect for 5s will be too much for 6s.and it works the other way. if i were planning on running two seperate cell counts in the same boat, in your case (5 and 6s) you would be better off getting a motor that will handle 6s well. sure, 5 s wont be a rocket, but you can switch props around to gain more speed. better than having a rocket on 5s and blowing up your motor on 6s… get it?
        • HondaHead
          • Mar 2012
          • 15
          I learned that from reading on here but thanks agian
          So once I get a motor(already have a 180amp esc ) I'm just gonna
          Run 2 3cells and be done
