mystic 29 hatch
  • injected CH3NO2
    • 5
    mystic 29 hatch
    hi all this is my first post been a member a while but always found the info i needed this is a great website. but i have yet to see a defiant answer about the thickness of the hatch as i know people had problems with the geico hatch breaking so question is is the mystic 29s hatch any thicker? i know it has flotation now but not sure about the thickness could someone please clear this up for me thanks john
  • stony30
    • Aug 2011
    • 36
    I've had mine for a couple of weeks now. I don't own the mg so I can't compare them. The hatch to me is a non-issue in my opinion. It doesn't seem at all flimsy if that's your concern.
    • petej
      • Jun 2010
      • 163
      Pro-Boat support is your best source to ask about the thickness of the hatch.
      I had the Miss Geico, flipped it many times at speed and it never cracked.
      Pete
      Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
      • roadrashracing
        • 1630
        Are your hatchs fiberglass? I seen a mystic today and it had a plastic hatch.
          If you run in cold water it will crack eventually. From what I have seen they are the same thickness & material.
          • petej
            • Jun 2010
            • 163
            My Miss Geico had a fiberglass hatch.
            Pete
            • desmobob
              • Sep 2011
              • 172
              Mine already has a small crack just ahead of where the grab loops are in the rear. I built up the area a bit with some J.B. Weld as I had to mix up a batch to re-attach one of those little grab loops... it pulled out of the hatch. This winter, when I blueprint the hull, I'll also add a layer of 'glass to the inside of the hatch.
              Take it easy,
              desmobob
