Just arrived my New V3 Geico
  • royalcasa
    • Mar 2014
    • 560
    My son and I bought the V2 he got the Geico I got the Blackjack. Ever since then I wanted a Geico and here she is, Bran new out of the box. My goal is to make some small upgrades. First thing to do is reassemble it, clean it then carbon fiber the nose and the seam, upgrade the flex shaft and strut, new 440 sharpened and balanced prop. My Blackjack has been running close to 50moh on 2 3cells since I got it with no issues. I am hoping to get the same results with the Geico. Not looking to break records just good sport running.
  • MADRCER
    • Feb 2017
    • 765
    Nice! You might consider mounting that motor in the other holes due to the way it's turned on the mount because you will only be filling half of the water jacket with water due to the water inlet being higher than the exit point. Or you might be able to twist the jacket a little with some pliers. It's a bummer yours didn't come with the new updated motor though. The Geico v3 runs decent below is mine.
    • royalcasa
      • Mar 2014
      • 560
      What is the difference between the original and the updated motor
      Wow 81 mph, did you reenforce the hull, what prop are you using
      • MADRCER
        • Feb 2017
        • 765
        The new 3831 motors have around 1/3 more power than the old 3910 motors have. The prop I like to run for straight line 6s speed runs are the abc 1716-17-45 props prepped from Chris Hoffmann (dasboata) on here. If you start upgrading props that's the man you want to get a hold of. As for the hull I brushed a light coat of T88 epoxy over most of the fiberglass seams and poured a some in the sponson tips to help strengthen the weak areas and that's all I've done to it. Good luck with it! Here is a little quicker run of mine as well.
        • royalcasa
          • Mar 2014
          • 560
          Thank you
          • royalcasa
            • Mar 2014
            • 560
            why no Breakaway propeller. I am sure some of you have upgraded to a breakaway propeller, what is a good replacement rudder.
            • royalcasa
              • Mar 2014
              • 560
              Ordered a SB 440 from Chris, ordered the Veles 29 brakeaway rudder set, OSE shaft and strut,
              • MADRCER
                • Feb 2017
                • 765
                Nice! Chris' work is awesome. You'll be back for more...
                • royalcasa
                  • Mar 2014
                  • 560
                  DE83AF29-2F24-491E-B3B7-74139A94ED2B.jpg7B1F7BC6-8C66-4EC7-BE6E-8B7E28FBCAAE.jpgCF00A248-9893-4F4D-8FA6-21CC31C9A18C.jpg3ECA1514-2CBB-4CBC-BA51-707AD3665A3B.jpgSome inprovements done, CF on the nose, I added epoxy to the seams. I reinforced the transom. Added pool noodles, new coupler, OSE flex. I got a strut from OES but the inside diameter is to big for the stuffing tube. Stuffing tube Diameter is .236” The strut ID is .257” Waiting for the brakeaway rudder and the S and B prop.
                  • MADRCER
                    • Feb 2017
                    • 765
                    Put a piece of heat shrink around the strut where it goes over the stuffing tube. This "slop" will allow for better angle adjustments and the heat shrink won't let your grease out easily and it won't let water in through your strut to wash away your grease.
                    • royalcasa
                      • Mar 2014
                      • 560
                      Put a piece of heat shrink around the strut where it goes over the stuffing tube. This "slop" will allow for better angle adjustments and the heat shrink won't let your grease out easily water and it won't let water in through your strut to wash away your grease.
                      I will give it a try
                      Thanks
                        I’ve always liked these boats. The v3 is much better than the old one.
                        • royalcasa
                          • Mar 2014
                          • 560
                          Me to, it’s agood looking boat
                          • royalcasa
                            • Mar 2014
                            • 560
                            87BD8EE5-A547-4984-8FD1-3A270EE3758E.jpgA145C5AC-8087-461F-86B9-65CC19D8762A.jpg01AEC977-116C-4200-AE54-3CB5FB1DEFE4.jpg584024DD-3A80-4BFE-B868-AE46CF36E512.jpg28BA6A2B-1B20-48F8-B2F0-7CD778BF84BF.jpgMadrcer, shrink tube came out tight on the stuffing tube, I looks good to lol. Veles brakeaway rudder bolts right on, only mod I had to do was to invert the pushrod. The Veles rudder is razor sharp. Prop should be here on Monday
                            • royalcasa
                              • Mar 2014
                              • 560
                              Question about the rudder, front edge was not ground straight. You can see the it does not Follow the Straight edge on the paper. I don't think this is correct
