Miss Geico 3V, Some good, some not so good,
  • Mitch S
    • Jan 2016
    • 47
    But good reading none the less :)
    So, I’m pretty new to rc boats, but decided to jump in head first. Been in and out of the rc hobby for years, I left off last right when Lipos took off. So, trying to learn all I can about lipos and the new electronics as well.
    Anyway…
    Jan 15th, I bought a new Geico 3v. So far I love the boat! Fun and fast! Per the Horizon website I’ve been running 6s, 5000, 50c.
    So, after 2 weeks and about 4-5 runs, I was running the boat and it loses power. Not talking about battery saver, it basically died. Luckily, right in from of me. I pick it up, walk into my house, take the lid off and a plume of tan colored smoke… Poof!!! And smelled kinda bad!! Ugh.. wtf…
    Sunday, nearly 6pm I figured I’d try to call Horizon, maybe leave a message. Nope, I get a real live person on the phone!! Within a 10 min conversation, he is sending me a brand new ESC AND MOTOR!!! I have never had such good Customer Service in my life!!! Horizon, you have earned my business!
    So, the parts come, I figured it was the ESC, so, I replace that first… fresh batteries, and Nope. Chug chug chug… It was the motor that fried. I did take temps after it burnt up, but it was a few min. later. Motor was around 215-220, so, again, probably much hotter a few min earlier. ESC, 120.
    My lake is very clean, I would be surprised if the cooling got clogged, but anything is possible.
    I’d like to add better cooling, but I cant seem to find a clean way to do it?
    So now I’m kind of hesitant to run 6s. Can you run 5s? a 3s and a 2s? Or would you just continue to run the 6s?
    One other thing, on the run that burnt up the motor, I had just bought a new prop, Octura 642, prepped from Dasboata. I cant imagine that could have caused the motor to blow?
    Anyway, I’m digging this site, lots of good reading! Thanks.
    • 7512
    How long were you running?
    What prop?
      • 7512
      Interesting...if you read the manual, it says to use Qty 2 , 2S packs...nothing about 3S packs. But the web page does say 2S or 3S packs.
      • JimClark
        • 5913
        Moved thread to the Geico forum. My bet you run it too long or too slow. How many MAH goes back into the Batts after your typical run?
        Billy Graham
        • Mitch S
          • Jan 2016
          • 47
          JimClark,
          Definitly not to long, because the ESC shuts it down when the batteries get to 3.8 i believe, and that didnt happen.
          Also, High Speed passes, pretty much full throttle, long u turn, then back, etc etc. Definitely not to slow or to long.
          and the batteries were about 3.9-4.0 each cell, if I understand you correctly.
          and Doby,
          Yes, the website says 2x 3s 5000 50c, which is exactly what I bought for the boat
          Also, this video, from Horizon, by the developers of the boat they state 6S compatible, https://www.youtube.com/watch?v=vAwjFpnGnRw
          Anyway, love the boat,
            • 7512
            What prop?
            • bigcam406
              • 236
              Octura 642 prepped from Dasboata
              • iop65
                • Mar 2013
                • 367
                i would never run that combo with 6s
                2000 kv , 36 x 62 mm motor and a 642 prop....
                you should really know how to set this up or things will go wrong
                love the boat ? use this with 4s or 5s
                regards
                • Mitch S
                  • Jan 2016
                  • 47
                  regards
                  iop65,
                  Can you telll me:
                  1. "Why" you would not run this prop? when that video link from the developers state that you can mess with different props? AND, its the correct battery for this boat??
                  2. Know how to "Set up" this boat? What is there to do? Its Bone Stock?? I'm not interested in "blueprinting" the hull.
                  3. In my first post, I asked about mixing a 3s with 2s. I guess the answer is Yes, I can? no problem??
                  • Mxkid261
                    • Jun 2015
                    • 734
                    Yes you can use a 2s and 3s but you should make sure they are the same c rating
                    • modvp55
                      • Mar 2015
                      • 131
                      Most of the guys in the club that have that boat run an x442 on 4s due to warm water, during the winter when water is cooler they sometimes will run the 642 but when running 6s you need to drop down in prop to allow the motor to reach the added rpm or it will over heat. I would get a good temp gun and make one pass at a time checking temp until you are sure it does not overheat. If you want it to last keep it at or under 125 degrees.
                      • iop65
                        • Mar 2013
                        • 367
                        yes, you can use 2s + 3s ,as long as they have the same specs ( mah +c-rate + brand)
                        and why not run that 6s combo you did?
                        i think you proved why Mitch and i'm pretty sure it will happen again when you'll try it the next time
                        you're new with these boats , so i would suggest to start with a lower voltage and adjust the strut/props and see what happens ....learn...there's a reason why the strut is adjustable
                          • 7512
                          When experimenting with props, do two laps around the pond and bring it in, open it up and always check temps....As you stated the motor was 200 plus degrees, you didn't do that.
                          When a manufacturer says you can run 6s, and use different props, they really should elaborate on a basic procedure on how to do that.
                          Don't run that combo again.
                          • Mitch S
                            • Jan 2016
                            • 47
                            Guys!
                            Thanks a ton. All good info, and taken to heart!!
                            Ordered a couple 2s packs, same specs as the 3s.
                            I'll mess around with it on 4 and 5s. and stock prop. Dont want to burn it up again.
                            ( Although I still dont think it was my fault :) )
                            I have a decent IR Temp gun, but, anyone run something like this?
                            Anything better out there?
                            • stangguy73
                              • Jun 2015
                              • 39
                              I had the same issue. I fried 2 stock motors on 6s with the stock prop. I run my Miss Geico V3 with a seaking 180 esc and a leopard 4074 1800 kv motor with a balanced and sharpened m545 prop on 6s and she screams. I changed the cooling lines over to a larger size and switched all of my connectors to 6mm bullets. I have no heat issues.
                              Miss Geico v3, Impulse 31 v2, AQ Motley Crew, Atomik Barbwire
