Which Dual Rudder? Mystic
  • smittyj77
    • 89
    Wondering if anyone has a working dual pickup rudder conversion working yet? Only problem is pictures are decieving as ive found out. The hardware is absolutley huge.
    I purchased this one from Kintec racing and its huge.
    5 Inch Rudder Short Base w/ Dual Water Pickup CNC machined aluminum rudder and mounting bracket with dual water pickups and servo arm. Brass bolt for kickback protection.
    5 inch (128mm) from bottom of mounting bracket to rudder tip.
    1 1/2 inch (38mm) from transom to leading edge of rudder.
    Transom foot print is 1.7" (43.4mm) wide and 1.26" (32mm) high.
    Rudder width tapers from 1 1/4 inch to 1.1
    Servo arm w/ 2mm swivel. All stainless steel locknuts, bolts and washers included.
    I also see that OSE sells this one.
    This SpeedMaster rudder assembly is made for large nitro and electric hulls 38" or larger. High quality aluminum, CNC cut to tight tolerances.
    The Rudder blade measures 6 1/4" long x 1 1/4" wide.
    We offer this with 5 different brackets.
    -Bracket with 1 1/8" of setback.
    -Bracket with 2" of setback.
    -Extended bracket with 4" of setback (pictured).
    -XL bracket with 5" setback.
    -XXL bracket with 6" of setback.
  • skyhighdiver
    • Jun 2011
    • 287
    Transom Mount Water Pickup Machined aluminum transom water pickup. A nice clean set up only requiring one hole for mounting. 5/32 brass pickup tube. $6.50 each KINETIC
    Works like a charm
    Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
    Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
    FAT PEOPLE ARE HARD TO KIDNAP
      • 4297
      Hi,
      Hear a link to some good info.
      http://forums.offshoreelectrics.com/...ro-Boat-Mystic
