Fixed my boo-boo
  • SpeedCat29
    • May 2013
    • 23
    Fixed my boo-boo
    I was running my MG this past weekend and had a little incident. I was about 200 yards offshore wide open in what looked like clean water. All of a sudden I heard a loud "thump" and the boat zig zagged in the water but was still going. I brought her in slow and to my dismay the top portion of the transom where the rudder bracket bolts onto the hull was cracked and pushed in. I had hit something underwater and unfortunately did not have any breakaway bolts on yet. I was pissed at myself and wondered what I should do....buy new hull? No. Fix this one? Hell yes! So I rummaged in my shop and came up with some thin scraps of aluminum sheet appx. 1 mm thick. I don't even know where I got it from in the first place, but decided it would work. So I measured and cut a piece that would fit the raised portion of the transom and then worked it to bend over the top of the hull. Filled in the cracked spots with some epoxy and voila! I have a sweet looking rudder mount that actually strengthens the rear of the boat. Just waiting on breakaway bolts and new steering boot.
    Miss Geico 29 V2
  • macace123
    Robotics Operator
    • Mar 2013
    • 477
    nice looks good i might have to do this on the BJ29
    Its not the boat its the driver http://namba2016fenats.com/
    Whiplash,Sprint Cat, Pursuit, 83' Miss Rock modern hydro JAE21, Dragon M11 Tunnel, Mickey Beez Jet, CF JAE21
    • SloHD
      Slow Electric Addict!
      • Apr 2013
      • 337
      I like it, looks sick man!
      • mhaseck
        • Dec 2012
        • 5
        does look really good, nice fabrication work! What prop are you running on your miss gieco?
          • 7651
          That is exactly what started all my FG playing. There isn't much in that transom area. I hit a stick in the water and ripped it all off. My repair is on here somewhere but yours looks great and skips the need for paint. Good job sir.
          • SpeedCat29
            • May 2013
            • 23
            Thanks guys....I am still new to these boats so that first time "carnage" hurt a bit lol. But that's all part of this hobby I suppose. I'm sure it won't be long before I break something else.
            Miss Geico 29 V2
            • ozzie-crawl
              • Sep 2008
              • 2865
              Looking good.
              Just a small observation as it mite be a different drive or just there for the pic but it looks like your drive dog/washer is up against the strut were as it should have a gap.
                • 5660
                Originally posted by ozzie-crawl View Post
                Looking good.
                First of all, your repair looks awesome, love that aluminum look.
                He is right, your drive dog /washer should have a gap between the strut, the length of the gap is the diameter of your flex cable. Forgive me if you already know and this is not how your set up is but just a photo thing.
                • SpeedCat29
                  • May 2013
                  • 23
                  Yeah, I just pulled everything up as tight as possible so the epoxy would squish nice and flat and cure that way. She'll be properly adjusted once it's cured for a few days.
                  Miss Geico 29 V2
                  • SloHD
                    • Apr 2013
                    • 337
                    Huh? Lol... They're not talking about your fix. They're talking about the spacing between the drive dog and the strut. Back the flex cable out of your collet a few mm so you have some spacing in between your strut and drive dog.
                    • SpeedCat29
                      • May 2013
                      • 23
                      Yes, and I purposely pulled the shaft up tight to make sure the strut was/stayed in contact with the stuffing tube (or whatever that's called) until the epoxy cured.
                      Miss Geico 29 V2
