Blackjack 29
  • brg65
    • Nov 2012
    • 15
    Blackjack 29
    Im new to RC boating but have experience in basic RC. I need everyones opinions on my Blackjack 29. I am replacing everything inside except the radio. Leopard 4074 1650 kv motor is going in. Hyrda ice 240 esc going in. Maxamps 3s 6500 mah x2 for 6s power is going in. I sharpened and balanced the prather 215 clone prop that came with the boat. Also ordered a x640 and x642. I plan on a 9 inch cog from transom, aswell as adjusting prop height. I would appreciate everyones input and thoughts on this setup, and any other prop recommendations.
  • driftah
    • 759
    sounds good except the lipos do some searchin bud maxamps is a huge scam,hyperion,dinogy,and a few others are the lipos you are lookin for,lots o threads on good batts here,I hate to see newbs ripped off....
    • brg65
      • Nov 2012
      • 15
      Lol well im a newb to boats, but have run the maxamps in my Heli and buggies, even in a baja 5b with castel creation conversion on 8s. I heard about the maxamp scam but in the past have had goodluck with the batteries they supplied for me. Im not advertising for maxamps, just sticking with goodluck. Thanx for input. Any other ideas on setup ?
      • silvermansteve
        • Aug 2009
        • 152
        i believe you'd have good luck. why not? i don't really know that there is anything wrong with max amps except for the price. if that doesn't bother you, why not get them?
        • siberianhusky
          • Dec 2009
          • 2206
          The requirement for boat batteries are far far different from the requirement of other rc vehicles, nothing else I am familiar with draws the amperage a boat does, people on here have run just about every brand of battery you can buy and only a few of them have proven themselves to stand up to the abuse from boating.
          I started out thinking batteries wouldn't make much difference and went with all cheapies, I have one single pack out of them that will still work, my packs that cost 2x as much so far have lasted 3x longer and are still going. WOuld have been farther ahead to buy better batteries the first time around.
          When you run a datalogger you really begin to see the difference in battery quality, the cheaper ones drop much more voltage under load which in turn puts more stress on the motor and esc. Done back to back tests between Gens ACe and Polyquest, the GA drop over a volt more under load, Kendt had the exact same results with GA 6s packs he tested. No more Gens ACe for me, two guys logging their runs with very different setups and both showed the exact same voltage drop.
            Can I offer to buy your blue Stock motor if it isn't used?? That is once you are sure on your plans...
            Thanks !
            Dinogy LIPOS are really awesome batteries. You won't be dissapointed.
            • driftah
              • 759
              +1 on dinogy,it seems that alot of folks are using these for top end saw runs with very good results.hmmm maybe I will get some too
              • brg65
                • Nov 2012
                • 15
                I think im gonna keep the stock motor, just to have around incase i get another project. thanx for the offer though. This is a great Forum and appreciate the help guys. Does anyone have a similar setup ? im curious about cog measurements to start. ive bin told 9 inches from the rear.
                  That is a starting point. You always learn alot more by experimentation.
                  • brg65
                    • Nov 2012
                    • 15
                    Im gonna keep my eye open for Dinogy batterys. Thanx for the tips.
                    • lomdel
                      • 722
                      Talking about batts and -position in the BJ29 hull, the plywood batt trays are a major weak point inside the hull. My boat ran over three/four small ripples in an otherwise smooth canal and when it came back, the trays broke loose and were sliding back and forth. It's a rather easy fix with some resin or CA glue, but they are really flimsy and weak... Otherwise, great boat. See pic of mine with a GoPro for some action footage...
                      • scrillamil
                        • Dec 2012
                        • 18
                        I had same thing happen w battery trays! But love the hulls just bounse a bit. I'm a newbee but we are running a Geico 29 & BJ 29. We ran stock BJ on power edge (2) 5000mah 3s 11.1v 35c. I just wrecked the MG so tryin to decide to replace w/ same or try Genesis 41" hull. What speed are you getting w/ that set up?
                        ProBoat 29 Blackjack stock & Miss Geico 29 (wrecked at the moment)
