Questions regarding Miss Geico
  • Sharky
    • 91
    Which one would be faster?
    Also what do you think about a set of turn fins?
    3 Rio 51z's, 1 Miss Geico, 1 Dumas Donzi Z-65, 2 enforcer's, 2 miss Budweiser's, 1 prather lap cat 7.5cc, 1 gators tours airboat, 1 blackjack 29, a few T-maxx's, a few others..
    • dana
      • Mar 2010
      • 3660
      Turn fins? Negative. No need for them.
      The two setups are close in Rpm, so it depends on prop and setup, but the stock pb motor is a nice motor.
      • dana
        • Mar 2010
        • 3660
        Is the stock motor the 1800 or 1500?
        • Sharky
          • 91
          I believe its the 1800 with the 42x55 grim racer prop
          I think i have 2 other props as well.
          • Skullcracken
            • 728
            The stock motor on the MG is only 1500kv. So 5s (18.4v) x 1500kv is 27,600 rpm's. A 2300kv motor x (18.4v) is 42,320 rpm's. Over 35,000 with some motors is "play at your own risk." You could get away with it if you want to do 4s for longer runs and 5s for very short runs - 2-3 minutes of passes.
            • Sharky
              • 91
              I thought i had the 1800. Thats what the guy told me it was.. Would it say on the motor?
              • dana
                • Mar 2010
                • 3660
                Is it a blue can or silver?
                • Sharky
                  • 91
                  The hull is lime green not yellow. and the motor can is silver with the blue water cooling collar.
                  • Sharky
                    • 91
                    So which is it?
                    • SirBudman32
                      • Aug 2011
                      • 701
                      silver can is 1500
                      Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                      • Jason4636
                        • 712
                        If your new 2300kv motor is bigger in size. Longer and bigger around, with the added length you have more torque to turn a larger prop. But watch your temps, when you step up on prop size.
                        1500kv x 18.5(5s)= 27,700 rpm unloaded
                        1800kv x 18.5(5s)= 33,300 rpm unloaded
                        2300kv x 14.8(4s)= 34,040 rpm unloaded
                        So in theory, the 2300kv should be faster. But more than likely you will pull more amps and run a little hotter on 4s. With slightly lower run times. Or just be like me, I run 4s2p
                        • Sharky
                          • 91
                          So stupid question..Running 4s is just putting 2 2s lipo's in it, With the way they are wired from factory right??
