Dual water pickup for Miss Geico?
  • Jason4636
    • 712
    Like the title says. What is a direct drop in, for a dual water pickup rudder for the Miss Geico?
  • Jason4636
    • 712
    Will this rudder work? In the MG bracket. Just the rudder
    • gtrcguru
      Radio Control Guru
      • 185
      i added transom water pickup to my mystic. worked awsome in the Okie summer. i also thought about the dually for the spartan before i chose transom.
      58" Venom Segad-48" Prather Deep Vee-41" Dumas 1/8 Hydro-34" Saga C1-32" Venom KOS P1-31" Pro Boat Impulse V1
      • lomdel
        • 722
        [ATTACH=CONFIG]85332[/ATTACH]
        What rudder is that? If the length and mounting holes are same as stock, it should work...
        • Jason4636
          • 712
          I just really wanted it cause it has 2 water pickups. If its to long I'll just cut it down. As long as the rudder itself's, where the pin goes thru to hold the rudder on is the same. I'll make it work. I might need to modify somewhat.
          • gtrcguru
            Radio Control Guru
            • 185
            dont know the specs on the spartan but it looked the closest to me.
            • Jason4636
              • 712
              The spartan only has a single water pickup. I'm wanting a double
              • lomdel
                • 722
                Which one is that in the pic?
                • Jason4636
                  • 712
                  I don't know who makes it? I just seen a dual water pickup blade and was wondering? Heres 2 on the OSE site.
                  http://www.offshoreelectrics.com/pro...s-rud-dual-tap
                  http://www.offshoreelectrics.com/pro...ros-rud-dualpu
                  I'd rather have the straight blade. Like I said earlier, all I need is just the blade. I already have an offset bracket on the way.
                  • gtrcguru
                    Radio Control Guru
                    • 185
                    http://www.offshoreelectrics.com/pro...R-blue&cat=123
                    this is the one i was talking about. its also in silver
                    • Rumdog
                      • 6667
                      Stock setup? Why do you need another pickup?
                      • Jason4636
                        • 712
                        I'm putting in a Leo 4082 2200kv with a Seaking 180a, plus in oklahoma the water gets hot during the summer. I just want a dual in, dual out setup for safety
                          Looks like that Spartan rudder should work for you Jason.Not cheap though.
                          If you look at this thread you can see it should be easily adaptable.http://forums.offshoreelectrics.com/...-Submarine!-X3!
                          • Jason4636
                            • 712
                            Would it work better than one of the other 2 I have above
                              Just thinking that the rudder assembly would mount to the angled bracket that is attached to the hull.They are both flat side mounts as opposed to hoping the hinge pin assembly would interchange. Assuming this is what you were thinking?
                              Unless you were thinking of somehow mounting the entire rudder assembly.
