Little Twin G
    How did boring out the slots work on the collet?
    Worked great Carl.Now if I can just find a 23 spline long servo horn for my Speky servo I'll be happy. Integy has some but no one local so far.Oh and I need to put foam and lead in the nose.
    • mtbenjamin77
      • 885
      #107
      Reverse your prop
      rotation and you'll loose the hop
        Originally posted by mtbenjamin77 View Post
        Reverse your prop
        Guess I should try that before doing anything too radical.
          Now why didn't you think of that.
          That help a lot with that twin mono from Finland.
          FastVee, I think.
            That help a lot with that twin mono from greese.
            Coolmines I think.
            Only the fourth run coming.It takes time to work this stuff out.Nearest water is 1/2 hour drive away. Props spinning inwards means dual rooster tails,I like that.
              Hear you go something from the past.
                So what powers that beast Len?
                  I think they were T600 880kv outrunners,
                  Link to build.http://forums.offshoreelectrics.com/...e-style-build)
                  I know he had a problem with a esc or motor at one point.
                  Also was not running good till he reversed the rotation and that did the trick.
                    I found in the Shocker that spinning outwards was all the difference.So that is what I did with this one.I'm playing at the race course tommorrow so I'll mess with it then.But for now going to put foam in today and I have the stingers set down a bit.
                    • HYDROJERRY
                      • Jan 2010
                      • 2709
                      #115
                      Yes please put some foam or something inthere, heck i was thinking of putting some in my rc drift car just cuz im so used to it,hahaha
                        I got some foam in there Jerry.And an inflatable rescue dingy today.I found the Twin can do other tricks too.
                        So I am off this week so I will try the props the opposing direction next,and get better vid.Sorry guys.
                        • HYDROJERRY
                          • Jan 2010
                          • 2709
                          #117
                          Well it looks like it cruzes pritty nicely shawn, and runs upside down hehehe, i have a blowup raft also and hate using it so i only try to run in the summer time so if anything happens i rather just swim for mine, i use diver fins so its not so tireing when i get to the boat!!! Last time i used my brothers fishing rod took afew tries but i got it hooked and pulled her in..
                            The raft will be good for the race course spot as others will be there as well.I have thought of using my rod,it is in the van, just haven't figured anything out for the end.
                            I think I may mulch up the lead that I have in there and epoxy it into the bow tips.Hopefully I can decrease the amount of lead this way.
                            • masonis1
                              If you cant control it 👍👍
                              • 1177
                              #119
                              Great build, this is awesome
                              When speed isnt the option, change your ways
                                Allright who was it that wins the $64,000 prize.Spinning the props the other direction took care of things on this one.I'll post the vid soon.I got to take advantage of todays break in the rain.
