Little Twin G
    • 7651
    Just grab a couple spare blades as the CF will dull them.Especially the motor mount plate that I made you(lots of layers).
    • tagasagwan
      Molino Boater!!!
      • 965
      Yeah they are multiple layers of CF. Very nice! Thanks bud!
      My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
      MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
        • 9438
        Sweet! Thanks for sharing!! Now I know what struts I can use if I want to do the same.
        • HYDROJERRY
          • Jan 2010
          • 2503
          Alsume Shawn!!!! I had a AQ Miss Vegas that ihad carbon plates as the front ride pads, worked pritty good and looked cool too, why didnt you use sv-27 stingers on it, think ive seen someone use them one an mg before but i could be wrong anyway excilent job on those motor mounts, nice and clean... Did i hear you make CF plates??? I would love one, they are so expensive for a little tinny sheet!!
            • 7651
            The only other Twin MG that I know of would be from our bud,"Tiq". Is that what he used.I didn't want to bug him but did hunt for a build thread from it to no avail.
            • HYDROJERRY
              • Jan 2010
              • 2503
              Yeah it was Tiqueman,,, i thought he used them but i could be wrong!!! why cant you just put the stuffing tubes straight out the hull and use them as stingers, tomuch vibration maybe??
                • 9438
                He machined aluminum tubes and glued them into the hull solid as stingers
                If they are robust enough and proper glue is used they are very strong. He beached it once and the stingers survived.
                • HYDROJERRY
                  • Jan 2010
                  • 2503
                  Thats it,,, new i saw them somewhere but thought they were cut down sv-27 stingers my bad,, Good catch there Ray, yeah now i remember cuz i told him i thought they looked like the barrel out of my 9mm pistal....
                    • 7651
                    Haha The thought crossed my mind of doing solids but this is only my second twin build and I did find I had to keep tweaking the Shocker(poor Shocker)as I tuned it and improved it.
                    Hey Ray how'd you get his pics?And where for that matter?
                      • 9438
                      I saved them from his build thread it's in here somewhere???
                        • 7651
                        I hunted and hunted and could not find that thread.It was before my time here. I know he is swamped busy so didn't want to bug him. That's OK,I figured it out.
                        So Ray,what do you think of my plywood ride pad idea there?I would go right up to near the front and maybe even step them a bit.Like my Shocker was.
                          • 9438
                          http://forums.offshoreelectrics.com/...ild&highlight=
                          This is the running twin thread. Can't find original???
                          A link might be in there somewhere??
                          The ride pad is o.k. as long as it is as short as possible at the transom. Just use it to create sharp edges.
                          Many other racers/boaters have taken Hydromarine Drifters and done similar to help the handling some but, they were much more narrow that MG.
                          Maybe start with it flat and try steps later? Many options...
                            • 7651
                            I was thinking of using it to cover that open spot on the stinger.That looks like a water in hull issue waiting to happen.
                              • 7651
                              The transom doublers are in with CF cloth backing and if I can remember today to get some latex gloves I will do the rest of the CF layup and pop the motor mounts in at the same time.
                              In cleaning the inside of the hull I discovered just how thin these are.Nothing serious but good thing I am doing a layup.
                              • HYDROJERRY
                                • Jan 2010
                                • 2503
                                are you going to repaint her or try to keep her original?? if so i have painted my turbine hatch and have a pritty close match to the original paint color if you need the info let me no..
