UL1 motor question
  • nitromt
    • 17
    UL1 motor question
    i wanna upgrade my geico motor and noticed some people using the ul1 im thinking of getting this one just wondering if its a straight drop in?
  • stadiumyamaha
    • 1371
    I have one in one of my geicos. It is a drop in as long as the esc connectors are the same.
    Works pretty well for my sons boat using 642 prop.
    • stadiumyamaha
      • 1371
      Oh. I'm running 4s2p in it.
        Another option is the AQ or PB 1800 motor. These are almost as fast as the UL-1 motor but draw less current, spin a larger prop and give lower heat. It is easier to burn down a UL-1 motor in a cat than one of the 1800 motors.
        • nitromt
          • 17
          Any heat issues with your sons? ill be running the same prop.
          • nitromt
            • 17
            Fluid i do have a motor from a aq supervee 27r kicking around will that one do? could i use that with stock esc? i will be upgrading the esc but i thought just to try it for now.
            • stadiumyamaha
              • 1371
              I've only run it a couple of times with that motor in it and so far no heat issues. I have the strut as high as possible but take care because you can raise it high enough that the prop will hit the bracket.
              Also, I run 4s2p which helps keep the heat down.
                I run the AQ1800 motor with the AQ60A controller, it is bulletproof so far. Yours should be fine.
                • CHIEFY_44
                  • Nov 2010
                  • 254
                  you can use the stock proboat esc no problem, as fluid says the 1800 is almost as fast and can swing a bigger prop, i have seen the 1500 proboat motor swing a 447 3 blade and runs fassssssssssssssssst, but you have to mod the prop a lot and im not sure what he did to it. But i know if i run the 2030kv motor in my gieco i have to run a M445 cut down to around 442 and runs good but just not as fast as it will with a full M445 on it, WATCH YOUR TEMPS and time your runs untill you get the right combo for your boat and setup.
                  Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
                  • nitromt
                    • 17
                    Ok thanks alot guys one more question will the water jacket from the stock motor fit on the 1800 motor?
                    • nitromt
                      • 17
                      I think im gonna buy a pb 1800 it comes with water jacket was wondering is the x642 prop fine with this motor?
                      • Boat guy
                        • May 2012
                        • 37
                        I replaced my stock motor with a ul-1. Much faster but runs hot. The water temp is high now, stock motor ran much cooler. I got a ul-1 cooling jacket but when it came it had a broken o ring so I used the stock pro boat jacket and worked fine. Question, it seems a little short on UL1 motor could that be the reason for the heat. Was running a 42x55 cut down grim racer. That is as big as it can go before it hits the strut, It was screaming before I hit something in the water and mangled the prop. I am going to put a 40x52 cupped grim racer back on that worked great w stock motor. I also bought a 40x52x3 for it, anyone tried it w a UL-1 motor.
                        Any other ideas to keep the new motor cooler w stock water set up. Have opened up the rudder hole but that's all on the cooling. Thx.
                        • SirBudman32
                          • Aug 2011
                          • 701
                          I run the 40/52 3 blade on my UL-1 with no heat problems at all.
                          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                          • Boat guy
                            • May 2012
                            • 37
                            Thx Sirbudman, are you running it in a Miss geico or a ul-1 hull. I am using a geico hull on this one How long do you run yours, I am worried about getting it to hot if I run for more than 5 min or so? And what are your motor temps after a 5 min run? The stock motor would be cool to the touch even after a 10 min run w 8s in series. Normally I run 4s -2p for speed. Is that the same for you. What about your cooling can. Did you use the ul-1 or miss geico? I bought a can for it but was cracked when arrived so I slid it into the stock pro boat and fit perfect, except I think it is a little short. Thanks for the help and any more you have. .
                            • SirBudman32
                              • Aug 2011
                              • 701
                              I actually run a UL-1 motor in two boat. One is a UL-1 and one in a SV-27. In the UL-1 it has the gold colored jacket on it and after a 4-5 min. run it comes in at 100 degrees and the one I have in my SV has the stock cooling jacket on it and after 4-5 min. run it comes in at about 110-115. Hope this helps.
