Dual pickup rudder?
  • yfzbrad
    • 35
    Dual pickup rudder?
    Does anyone know a dual pickup rudder that fits the MG? Maybe one that will fit the stock rudder bracket? I really want to do a separate cooling line for the motor and for the esc. I would really rather run a dual pickup rudder than a second separate pickup, for drag reasons. Any help would be appreciated.
  • Make-a-Wake
    FE Rules!
    • 6057
    You can get the big 6 incher from here on OSE and hack off an inch and a half or so, I've done it once, works fine.
    • yfzbrad
      • 35
      Do you have a part number? I want to use just the blade on the stock MG bracket.
        You may need to modify.
        Using a water pickup made of brass tubing in a sponson is a cheap and excellent way to add cooling that is hidden.
        • Make-a-Wake
          FE Rules!
          • 6057
          Here's the tapered one you can use, you can cut it off at the shadow edge where i put the line, or somwhere in there, then you smooth it out and shape the bottom of the rudder as you choose. You can buy the "blade only" for $24.95
          http://www.offshoreelectrics.com/pro...s-rud-dual-tap
          • yfzbrad
            • 35
            Thanks wake. I'll be ordering that right now. I think that is the best way to go without drilling more holes in the boat, and without increasing drag.
            • Garrett
              • Mar 2012
              • 140
              Impulse 31 dual rudder assembly
              you could try adding this to your boat, I'm seriously considering it on my mystic.
