4074 2200kv Leopard Seaking 180a.
  • Big Lebowski
    • Apr 2012
    • 62
    4074 2200kv, seaking 180esc, m445 s/b/t, 25-50c 6000mah nano techs running parallel. When i give it full throttle its seems slower than stock. Settings on my seaking is 1-1 2-4, 3-1, 4-5. Others please feel free to chime in.
  • skyhighdiver
    • Jun 2011
    • 312
    you need to recalibrate you throttle
    turn radio on
    pull full throttle
    plug in esc while holding full throttle
    when you hear 2 beeps let go throttle you will here one beep
    lets you know that the off is set
    then you are ready same set up in my boat run 53.8-55 depending on water conditions
    you will find very short run times with those batterys like 1.30-maybe 2 minutes before they get hot at 230 they will get puffy
    batterys are the week link in this set up, you average 120-130 amps esc cool motor cool batteries hot
    I went to nano tech 5000 65c get 3 minutes before batteries start getting warm
    Ok so I have 3 different batteries sets now.
    after 3 identical timed 2 minute runs, all within 30 minutes of each other on same wind and water conditions.
    My Miss Geico
    Using Leo 2200kv motor, hobby wing 180A esc, M445 prop
    Here are the findings:
    .................................................. ................................................ MPH....Temp....Replaced mah
    2 Turnigy nano-tech 4500mah 4S 45~90C Lipo Pack............................ 48.3......123.........4650
    2 Turnigy nano-tech 5000mah 4S 65~130C Lipo Pack...........................53.8........98..... ....4480
    2 Turnigy(blue) 5000mAh 4S 40C Lipo Pack........................................ 47.5......118.........4583
    Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
    Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
    FAT PEOPLE ARE HARD TO KIDNAP
    • martin
      • 2881
      Skyhighdiver what lvc voltage are you using on the 180a esc & have you had the lvc cut in early at all.
      • Big Lebowski
        • Apr 2012
        • 62
        I did what you said and still slow. Could the esc be defective? Bad motor? Let me know what you think?
        • skyhighdiver
          • Jun 2011
          • 312
          I have set on 3.2v but am going to push it up to 3.4 as I dont always run wide open
          some times i run for a while then float then run again later
          Dont need to push the cells anymore than nessasary
          I have never had the cut off kick in on my 2 minute runs but have when fun running
          Seems like my fun running although 3-4 minutes run time but in spurts going to lv cut off the batteries are cooler than 2 minute wide open
          and all balance out well the 65c are by far the best ones i have more spunk and much better run time.
          Notice I updated my post those mah replaced were from the two 4c not one 4c
          • d.a.v.e
            • 230
            I'm surprised you get as much run time as you do..
