Two 4S Packs in a Miss G??
  • Darin Jordan
    • 9446
    Hey Guys,
    I've never had the opportunity to try it... Have you been able to fit a 4S pack on each side of the Mystic or MG hull with the stock battery trays??
    If so, what size were the packs?
    I'd measure myself, but I'm not at home right now, and am trying to figure out some battery strategy and just how much I can fit in one of these...
    Thanks,
    Darin E. Jordan - Renton, WA
  • jasoncyclone
    • Jun 2011
    • 495
    I have had 2 4S Turnigy 5000MA 40C batts in my Geico. It was really tight getting them in and out but they fit!!
    Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
    • skyhighdiver
      • Jun 2011
      • 312
      I use both turnigy 5000 4s and nanotech 5000 65c and both fit on tray alittle fun getting in and out but work great I think it helps the boat the extra weight seemed to stable her out
      Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
      Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
      FAT PEOPLE ARE HARD TO KIDNAP
      • TheShaughnessy
        • 1461
        5000s fit. I've been using Gens ace 4000 mahs cause the fit better. If you drop the trays, the 5000 s fit no problem
          Thunder Power 5000 mah in mine.It got easier when I trimmed the trays and lowered them.I also dremalled the rails down up by the motor. But they do fit stock.
          • Mike_Shepard
            • Mar 2012
            • 44
            Any pics? I've been curious about this myself.
            • Boat guy
              • May 2012
              • 37
              They fit but it is tight. Can pull gently to fit past the cooling tube. Works great for me. My trays are stock.
              • stadiumyamaha
                • 1371
                I've found 4400mah fit the easiest with good run times. 5000 can be done but its a pain.
                  Here are some pics of mine in the old configuration.In the fourth pic you can see the trimmed rail by the motor.You can also trim the inner lip where the tupperware lid goes.All these things aid in easy instal&removal of the batteries(this one is not done).
