"that" miss geico
  • masonis1
    If you cant control it 👍👍
    • 1173
    "that" miss geico
    So hey everyone, ive gotten a lot of great help on here from people such as shawn "srislash", izcain and many other. They helped me with my first build and have started helping me with my MG. Now i kinda dont want my first build thread to be linked with my mg. I want them both to be seperate because truely, they are totally different. So thanks again and here, i want to get help for the MG only. Lets focus on this beast making it the best we can.
    So with the specs of the MG i have.
    Proboat miss geico hull
    Proboat steering servo
    Stock motor mount
    Aquacraft 120amp aquastar water cooled esc
    UL-1 brushless motor
    2 flight power 5350 mah 2s lipo
    Grim racer 42*55 prop
    Offset rudder
    Sharpened rudder and strut
    Traxxas 2.4ghz radio
    That is what we have. Now here is the setup shawn and i have put on with this boat.
    Strut is level with the bottom of the hull. While sitting on the table, the strut sits flat.
    Everything in this boat seems tip top. But i want more, who doesnt. Hah well im guessing you want pictures now.
    When speed isnt the option, change your ways
  • masonis1
    • 1173
    In some pictures you might see some stuff wrong. I have! Re bent the steering rod and as i said fixed the strut from other pictures..
    This thing is mean looking.
    Oh did i mention i traded my min revo for this! Great trade.
    • masonis1
      • 1173
      So now that everyone has all the detail, what does everyone see with this setup? Anything that can be changed? Anything cheap, that can be done?
      • masonis1
        • 1173
        Got rid of the butt connectors. Not pretty tho.
        Sent from my SPH-D700 using Tapatalk 2
        • masonis1
          • 1173
          So tested today. Couldnt go far because the range on the remote was limited. I actually his a wall lightly. Came back and noticed a crack on the inside side of the sponsor tip. I can blow on it and it wont let air through so im not worried aboht it too bad. Swappes over thee radio and i might go test again.
          • masonis1
            • 1173
            i did notice the take off and speed was better after i adjusted the strut. even with the short distance i could drive, perfect. hahah.
            • masonis1
              • 1173
              Originally posted by lenny
              Hi,
              How does the flex shaft feel going into the coupler on the motor ?
              In the pictures it looks like a bad angle on it.
              And 5.5 bullet connectors would be a cheap good mod all around for the setup,
              You just need to know how to solder.
              A mini torch is cheap and work good.
              It seems alright. Nkt too bad. But i dont know this... On my 2700 turnigy it spins smooth and easy. This motor doesnt. Like goes then stops when i try.spinning it. I.notice my cc2200 in my truggybdoes that too is this normal? And i have a torch and a soldiering gun. I can solder alright...
              • masonis1
                • 1173
                its the motor shaft that makes it hard tho... the shaft spins free.
                • masonis1
                  • 1173
                  Hahah
                    • 7651
                    Your truggy has a CC 1515 in it? Not for long...Tehe
                    • masonis1
                      • 1173
                      It has a mamba monster max 2200 kv brushless motor. Hah dont think about it.. Ill find a used one on ebay if i.need to
                      • masonis1
                        • 1173
                        Tork 2200 brushless. Just a flux motor but cc internals. 51 buckz. Yes? How could a water cooling work? Shave down cooling fins?
                          • 7651
                          That is exactly what's in mine.There are cooling cans for it.
                          • masonis1
                            • 1173
                            Sounds good. I might have to get it... Hahah
                            • masonis1
                              • 1173
                              So I've notced some talk I dnt understand. Ride wet, ride pads. Now also, ill try getting avdeo of the boat running as soon as I can. Probably memorial day week I will have a rc bash, ill have my truggy bashing and also the boat. Souldbe good. And also, im., getting a job so should hve some more money coming in.. first I'm going to buy my truck and upgrade tha a bit but I have half a year to do tha. I shoul buy a good setup for this boat. Motor? Used cc 2200 maybe. Esc idk what everyoneis running but I do have a extra 120 a esc. Maybe combine the two? Just a thought.. prop? Blue printing thehull sounds like a must. Ill have to findut how to do that. Now I see lik turn fins and stff for v hulls. Do these d anything for cats?
