I was wondering if anybody has made battery holders, or has any ideas for some. i was using what they gave but sticking the battery on the velcrow ripped the holder off. i feel that there has to be someone out there that can help, please show links or pictures i really appreciate it thanks.
battery holder help and question
Here a few nice battery holders from Switzerland:
They are CNC cut but you could cut/file out also something similar of a 2-3mm thick GFK sheet. Depending on the hull you want to use it and how many cells you want to fix.
regards,
Manuel
Just put them back in and use exopy to glue them down good and you will have no more problems . I run Turnigy nano-tech 5000mah 4S 65~130C Lipo Pack velcro to trays many high speed flips and all ok
The just did a crappy job of attaching them on all the boats from factoryMiss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
FAT PEOPLE ARE HARD TO KIDNAP
I use 5 minute epoxy that pre mixs in the tube as ou push out no mixing that way has held up great
Originally posted by CoreyM View PostDo you recommend a apoxy?Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
So should I be putting a piece of Velcro onto the battery tray and one on the battery to keep the battery held down or should I use Velcro loop straps to hold the battery down after I re apoxy the trays back into the hull? I got my boat used so I'm not sure how they are installed stock. Thanks
