Setup
  • Rich15
    • Feb 2012
    • 5
    Setup
    I currently own the Pro Boat Miss Geico. I was thinking about this setup.
    Lepord 4082 2200KV
    Turnigy 180A Brushless ESC
    Octura X645 Prop
    2-3S 5800mah Batteries
    Any input or suggestions would help.
    I was also thinking of keeping the Miss Geico stock and buying a larger hull then adding motor,esc, and other hardware.
  • jasoncyclone
    • Jun 2011
    • 495
    I dont know if the 4082 will fit under the hatch???? Also 3S in series will be to much for the 2200KV. I run my 2200KV on 4S and it moves pretty well. Temps are low also!
    Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
    • Make-a-Wake
      FE Rules!
      • 6057
      Thats a 4s motor, and a 645 may be a bit much, try an x445
      • Rich15
        • Feb 2012
        • 5
        So if I went with the Lepord 4074 which KV would you suggest if I wanted to run 2-3S in series and which prop would you go with. I was still going to go with the 180amp ESC.
