Your MG that started off as a hull
  • macdon
    • 970
    #2641
    Hey Jerry,
    While Im probably the least knowledgable guy here when it comes to mono, I'd still offer my advice to erase what you've done and go back to the basics. Monos are pretty picky in setting up but very stable when you get it dialed in.
    First check CG. At a total length of 32", cg should be at 9.5" measured from transom. Thats about 30%, so try to stay within the 9.5"
    Get a 12" metal ruler, turn the boat over and check for hooks - if there is, even them with bondo. Bring your stinger back to neutral.
    Using your turnigy esc program card, lower the esc failsafe protection to 3.2v but do watch your run time. Some have opted to "no protection" but if you extend your runtime your batts may bloat.
    Speaking of batteries, are they new or old? Are you constantly cycling them? There have been cases where LiPos sleep, so whether you get to use them or not, storage charge (cycle) all batts. I know its a pain to storage charge a full charge batt, but it will prolong its life.
    In the hobby of electrics, one of your biggest investment should be a good battery charger - your batts are the life of your electrics so its paramount to properly maintain batteries.
    • HYDROJERRY
      • Jan 2010
      • 2709
      #2642
      Ok Mardon,, yes i always do storage and ballancing on my batteries and they work great in my other boats so i dont see a prob there,, see my hole problem is when i was running it on the PB plastic MG prop it was great speed and handling but after two escs giving out and braking the plastic props now with the turnigy esc and my other props it took roles to the wright like i cant even get it upto any speed!!! i have tryed many props and it just wont stop..
      • CHIEFY_44
        • Nov 2010
        • 254
        #2643
        Set ur timing to 11.5 with that motor and esc combo and watch ur temps but that proboat 1500kv motor can swing a big prop no problem
        Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
        • HYDROJERRY
          • Jan 2010
          • 2709
          #2644
          Ok Chiefy so what prop do you recomend?? I have tfl435,x442, x642,m445 and a x447 i think..o and a GR 40x52 3blade.
          • CHIEFY_44
            • Nov 2010
            • 254
            #2645
            Try the 642 or gr40x52, I run a aq2030 in my gieco with a m445 cut down to a 442 it runs great so you might just want to go straight onto the m445 and work up, just watch ur temps, I req you do some testing run the boat for 2 laps and then take temps if they are gd u can try a bigger prop. Remember I tune my boats to run 6 laps so I am running my motors hard if your just running for fun you really need to keep a close eye on temps don't over prop a.other thing is you have to tune the hull so you not putting loads of pressure on the motor, I have turned down the timing and ran a M545 on cats a sport hydros. I'm sorry I cannot help much futher but its all about test, test and more testing, hope I have helped you a little bit and he luck.
              Bear in mind Jerry that the plastic prop flex's so the metal one is going to draw more. Should step down a bit and try that.
              • tagasagwan
                Molino Boater!!!
                • 995
                #2647
                Christmas in August??
                Santa stopped by my shop today and dropped these off! Yeeey! (At Last! after four attempts, it was finally delivered by Forex!)
                My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
                MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
                • IndyHobbies
                  • Feb 2012
                  • 130
                  #2648
                  I put the Pro Boat 1800Kv and their 60 Amp ESC in my Miss GEICO. What prop do you guys suggest I use? It had the 1500Kv/45amp ESC in it. Those went to my Impulse 26.
                  www.IndyHobbies.com - Bringing Indiana Modelers Together
                  SSMA #01M9382
                  • CHIEFY_44
                    • Nov 2010
                    • 254
                    #2649
                    Try a prather 220 prop should be good
                    • jasoncyclone
                      • 495
                      #2650
                      I'm so glad that you got the boat! Is everything good? Any damage?
                      Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
                      • tagasagwan
                        Molino Boater!!!
                        • 995
                        #2651
                        No damage or cracks. You did a great job packing it! Thank you also for the extra gas parts. I really appreciate it! So, what are you building now? I saw you trading your Cyclone on the Dock. Hate to see that boat go man! unfortunately I don't have any gasser to trade. But I love that blue cat! lols!
                        • jasoncyclone
                          • 495
                          #2652
                          That's not my cyclone. Its my thunderbolt twin that I am thinking about trading...
                          • tagasagwan
                            Molino Boater!!!
                            • 995
                            #2653
                            Oh yeah! That's your thunderbolt. My mistake! Well, still love the looks of that boat! Just out of curiosity, how much would that boat sell?
                            • jasoncyclone
                              • 495
                              #2654
                              About $1600 plus shipping
                                Hey Jason,long time no hear...
