Your MG that started off as a hull
  • skyman
    • May 2012
    • 290
    #1951
    Originally posted by jasoncyclone View Post
    If you do a search for blueprinting you will find a detailed thread about what I'm talking about. Basically you flip the boat over and take a nice flat sanding surface 12 inch minimum length, and start lightly sanding the bottom of the sponsons to get them perfectly flat. You will find that the ride surface is not flat we call this "hooks". After sanding a little you will find that you will need some glazing putty for the low spots. After the putty is dry, you sand again. Keep doing this until the ride pads are nice and flat. If you do this, you should do more reading up to make yourself familiar with the process. This will make the boat faster and alot more consistent when driving!
    Thanks for the info bro! So I'm guessing I will need to repaint the boat?
    Sent via Tapatalk
    Axial Yeti XL - Traxxas Slash 4x4 (x2) - Losi Mini 8ight - Tacon Soar Buggy - Blade 120SR - Miss Geico 29 (hull + parts)
    • skyman
      • May 2012
      • 290
      #1952
      i will do that
      I also you a small torch to do my soldering...
      noted, i think i might get one and try
      • skyman
        • May 2012
        • 290
        #1953
        jerry, take a look at what else came in today for the slash. gpm front/rear shock towers. supposed to be pretty good. i don't like strc two-piece version.
        ...and my first ever rc driver mag, take a look at the top of the page
        • macdon
          • Jun 2011
          • 970
          #1954
          My blueprinting on my MG..........
          Look at the 4th pic - the inner corner of the ride pads should be sharpened - perfectly sharp 90 degrees.
          • skyman
            • May 2012
            • 290
            #1955
            welcome back mardon, how was the boating today?
            how did you find the right paint color?
            • skyman
              • May 2012
              • 290
              #1956
              Originally posted by HYDROJERRY View Post
              And just wanted to show how easy it would be do make a standoff for your gear, i did this in about 15min last night on my Genesis,, first removed the rudder, had some long bolts so i drilled out the bolt holes that connected the rudder to the strut,, took a short measurement then found some tubeing just bigger then the bolts, cut them down the put the long bolts threw the strut bracket then slipped the tubeing over them then put on the rudder and nuts and here you have it!PS everybody loves pics..
              jerry, i'm not so much worried about the standoff, it's more that gap between the strut & the stuffing tube underneath. that part seems hard to make. anyway, i'm not there yet and worst case scenario, i'll just get the m29 strudder. that one should line up properly, right? and it's made better than the mg29 strudder?
              • macdon
                • Jun 2011
                • 970
                #1957
                Had soo much fun today! Our usual Sunday became a Saturday sched this week and I just brought my gas boats. My Geico mono had a problem with the adjustable stinger, so it had to sit it out. Good thing I got my R-42 Cat with me, so it was the only one I had to run today! What a blast - I love it!
                Stephen had a bad rudder servo, so he didnt get to play much - but when his Top Gun arrives (courtesy of Jason) atleast he would have an alternative if one gets busted on the pond!
                Nope that doesnt match. The green color I re-painted my ride pads were kinda avocado-ish in color. Its darker than the stock MG fluorescent green but I like it :)
                • skyman
                  • May 2012
                  • 290
                  #1958
                  i'm glad you had fun. too bad stephen didn't
                  do you have a brand & paint color number? was that the best matched color you could find?
                  i need to buy glazing putty right?
                  • macdon
                    • Jun 2011
                    • 970
                    #1959
                    The stock MG strudder is in-line, while the stock strudder of MC (Mystic) is off-set. You want the offset, so get the MC29 (Mystic) strudder instead. This will solve you the ff:
                    1. no need to buy offset posts or any other brackets
                    2. It 'may' align' the existing transom holes of the MG
                    3. It might just be a bolt-in stuffing tube to the strut
                    Eliminate some problems so you can concentrate on blueprinting and reinforcing of the hull. They might be a bit tough and time consuming at first but will save you lots of problems down the road.
                    You dont want to do those mods once you are already running and have all the electronics and hardware installed. do it right the first time, so you'll be trouble-free on its maiden run and hopefully beyond!
                    • skyman
                      • May 2012
                      • 290
                      #1960
                      yes, that's what i want to do. so i should focus on the blueprinting and inside the hull? should i be removing all that wood? am i reinforcing with fiberglass?
                      i wish one of you guys were here so i could drive over and have you do it
                      • macdon
                        • Jun 2011
                        • 970
                        #1961
                        As for removing the wooden deck, the other guys here didnt and I dont think they encountered any problems. Me, I just want it out so I could have a cleaner slate of whatever modifications or reinforcements that I want to do. I dont wanna say I didnt get to do this or do that because the wooden tray was in the way. Of course, this is just my way.
                        Since you're from Ca - maybe you can pm Jason for his number and maybe you can give him a quick call as he's from Ca as well.
                        • skyman
                          • May 2012
                          • 290
                          #1962
                          yea, i might just do that. he's only a couple hrs away. i think he lives in the bay area, we love going there with the family. my wife and i esp. love going to SF for seafood or italian in north beach (italian ghetto). our schedules need to sync up though.
                          tell me, how can you do the reinforcement with the wood in the way?
                          • skyman
                            • May 2012
                            • 290
                            #1963
                            ProBoat BlackJack 29 Video
                            • macdon
                              • Jun 2011
                              • 970
                              #1964
                              I think that Shawn would be the best person to answer that.
                              For me, I just want to reinforce the floor of the Cat - aside from the area where the stuffing tube exits, all electronics sits on the floor so I wanted another fiberglass layup on that part. I also want to add another layer of fiberglass on the seams all around the hull and the transom. So I felt that having the wooden tray out would give me ample space to manipulate my hand holding a brush applying resin as well as positioning the fiberglass matt.
                              We even poured resin 1-1/2" deep on both tips in the front for added strength and a bit of weight.
                              • tagasagwan
                                Molino Boater!!!
                                • 965
                                #1965
                                Did somebody mentioned seafood? Hehehe! We had mud crabs, shrimps and grouper last night. Tonight its all veggies. Hehehe!
                                I had some proplems with my gasser today. Well, that's life! At least a had the whole afternoon messing around and of course, I always pick on Mardon! Hahaha!
                                My Aquacraft SV27's old Video: http://www.youtube.com/watch?v=VoTm4Btz41Q
                                MHZ Micro Iceberg, Skunksworks Gen2 Cat twin, Aquacraft SV27, SM29 1515 sold.
