Thanks. That would be great. Found some CF at a fiberglass supply. They said another guy was there looking for same thing. I will give a close look at the tube to see if cracked through. I'll send you a PM later. Thx a bunch for the help. May have more questions when I get to the tube. Do you live in Srq?
Transom fix
Parrish, about 20 min north from fruitiville
You got the idea. I would just order another one.Should have a backup anyway.That wobble will tear out the strut.And the lead teflon bushings will be done in one one run.Originally posted by Boat guy View PostHow do I know if my shaft is bent. Went through it all and the shaft does have a wobble when the prop is off. How do I know if it's bent. Pull it out and roll it flat on a table.
Thanks!Originally posted by srislash View PostIt's All Gooood
I was so wrapped up with the date
that it did not occur to me that you were the OP, with 4,300+ posts
, of course you would have responded. So once more I say sorry, no disrespect to you, sir!
