Running 1800kv Stiletto motor and esc
x642 sharpened and balanced
high timing
2 -Turnigy nano-tech 4500mah 4S 45~90C
5.5mm on all
best time todate is 48.1 up from when we made our video
Having no heat issues with the esc ,motor or batteries
all are under 135 even after 6-7 minute run wide open
I im having heat issues with the connections between esc and motor 195
I changed them out to 5.5mm witch has made no change even had 2 desolder
So should I move the esc up front shorten the esc wires and direct solder them together to motor wires no connectors
or what do you have in mind
Hate to run low timing and lose almost 9mph just to keep the conection cool when the rest of the system is up to it
the ones that have come lose have both been on the motor side
hot enough to melt wire marks in my gps
Video http://youtu.be/Rhi4R_a_0gU
high timing
5.5mm on all
