5.5mm covers ?
  • skyhighdiver
    • 287
    5.5mm covers ?
    Just switched everything to OSE 5.5mm connectors
    what are you guys doing to keep the ends from shorting together when Storing batteries
    do they make plastic plugs or what
    Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
    Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
    FAT PEOPLE ARE HARD TO KIDNAP
  • eboat
    • Aug 2007
    • 693
    I just use a plastic valve stem cap off some old car tires we had around
    With the shrink wrap on the 5.5 female end made them the right size to twist on
    • skyhighdiver
      • 287
      Thank you great idea works fantastic and didnt have to order anything just went to the mall and they were all over the parking lot
      • HYDROJERRY
        • Jan 2010
        • 2503
        i went to the auto parts store and bault a little asortment of vacum caps cheap!!!
        • JimClark
          • 5902
          I got a flexible vinyl cap from McMastercarr that stretches
          McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
          Billy Graham
          • skellyo
            • Feb 2010
            • 592
            http://www.mcmaster.com/#push-on-caps/=ddp1uc
            I picked up some from mcmaster also. I got the vinyl caps with the pull tabs. They are a tight fit, but having something to grab to remove them is nice.
            • ron1950
              • 3024
              when i was at the nats i saw someone we all know with a 99 cent pack of pencil errasers..(from wally world) .they fit perfect over the 5.5's and come about 20 to a pack
              • JackBlack26
                • May 2007
                • 903
                I have never had a 5.5 connector short out. Even using stainless steel tables as work benches. I just leave the heat shrink on the positive lead, female connector, a bit longer than necessary. No sparks yet.
                • skyhighdiver
                  • 287
                  yet another great idia man you guys are full of them
                  • GP73
                    • 544
                    I use heatshrink, put a 1/2" over the connector, with a 1/4" sticking out, add heat, squeeze the part that is sticking out (with caution since it's hot) and you're done...
                    • egneg
                      • 4664
                      I use the same thing for caps ... you get 100 for a little over $3.00
                      IMPBA 20481S D-12
