Will it explode!!!
  • MissGeico
    • Jul 2011
    • 14
    Will it explode!!!
    Miss Geico 45amp ESC......(2) 2s 5000 batteries......Leopard 4047 2200kv motor......x442 prop.....
    Id like to know before I kill something.
  • Nealkot
    • 50
    I would upgrade to a T-180, and then you will have a great set up. As it is now, you are likely to freak out that esc, if you run it like this, bring it in after 1 minute (seriously) and temp. everything and keep your runs very short. But i IMHO you should just get at least a 150 amp esc.
      • 7512
      Whats the C rating on your batteries?
      • tunnelvision
        • 819
        Get a T180 no doubt. That motor can pull over 150 amps easily. Where theres smoke there's
        Go Fast...Turn Right...
        • skyhighdiver
          • Jun 2011
          • 312
          What is the expected temp of esc, batterys, connectors,and moter suppose to be as called normal run time and what is high
          Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
          Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
          FAT PEOPLE ARE HARD TO KIDNAP
          • ron1950
            • 3082
            id say the esc will pop some magic smoke if u go that route.......i have the same set up in a p mono but use the t 180 and the etti cap bank
