Kintec offset rudder v2 pics
  • JPriami
    N4FOX
    • 1711
    If anyone has the kintec offset rudder v2, may I have a couple pics of it installed so I can see what it looks like?
    I ordered one for my MG and want to see if need to do some trimming to make sure larger props clear the mounts.
  • ron1950
    • 3082
    i have one and if u want to run bigger props and raise the strut up some u will have to trim the bottom corner of the strut brace...its a easy fix with a dremel....u dont have to trim anything on the kentec stuff
    • Peacock8
      • Jun 2011
      • 97
      I have the one that he is selling on the netshop now is that the v2? I have pics I can upload.
      Edit: Here´s the pics anyway, that´s a x642 installed. with 3-4mm of clearance from the bracket.
      Ørjan.
      • MTboat
        • May 2011
        • 11
        bent 2 off set brackets
        I have bent 2 of these brackets. both on drift wood. is there any other options out there?
        • Peacock8
          • Jun 2011
          • 97
          I would suggest using a plastic bolt on the lowest mounting point on the rudder so the bolt breaks instead of the bracket. you can see it in my pics it worked for me when i hit some drift wood in the ocean :)
          Ørjan.
          • MTboat
            • May 2011
            • 11
            thanks i will try that.
            • JPriami
              N4FOX
              • 1711
              Got mine today installed and trimmed the back off the bracket that hangs over the prop. So I don't have to worry about it hitting with adjustments and larger props.
              • smoktf250
                • Jul 2011
                • 17
                What do you guys think about using those plastic bolts for both rudder slots?
                • Nealkot
                  • 50
                  [QUOTE=JPriami;339191]Got mine today installed and trimmed the back off the bracket that hangs over the prop. So I don't have to worry about it hitting with adjustments and larger props.QUOTE]
                  That looks like a real clean trim job, and i'd like to do the same. Would you let me know what you used, and/or how you did it? Thanks!
                  • Blockhart
                    • Jun 2011
                    • 39
                    Peacock8,
                    Where did you get that antenna?
                    Miss Geico?
                    • Peacock8
                      • Jun 2011
                      • 97
                      Its partly homemade. The alu mount I bought at OSE, I put a alu spacer underneath it for added support. The tube is evergreen plastics that i painted black.
                      Ørjan.
                      • JPriami
                        N4FOX
                        • 1711
                        [QUOTE=Nealkot;344000]
                        I just used the metal cut off wheel on my dremel. Then filed the end and edges a bit.
