Where to mount extra water pick up tube ?
  • wppracing
    • 109
    Where is the best place to mount an extra water pick up tube ? I want to supply the 4074 motor and 180a esc with seperate water flow.
    Watercraft Performance & ATV
    wppracing.com
  • G-UNIT
    • 971
    You could mount one on the transom or check out cooling tips on ose, like in hull water pickups, I did this on my BJ and it works well.
    • wppracing
      • 109
      I got one from OSE
      http://www.offshoreelectrics.com/pro...prod=ose-80410
      wppracing.com
      • G-UNIT
        • 971
        Yea that's a nice one.
        • skyhighdiver
          • Jun 2011
          • 312
          Does it not create drag on the side it is placed. Do you need to add one both sides of transom so boat runs straight
          Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
          Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
          FAT PEOPLE ARE HARD TO KIDNAP
          • JPriami
            N4FOX
            • 1711
            I have one of those I havent used yet. I was thinking about buying a 2nd one, and mount them both to do away with the rudder pickup and hose. I might mount one on each side underneath the boat behind the end of each sponson. They would pipe directly inside the hull thru the overhanging back of the boat that exceeds past the sponsons. This would give good flow and hide the hoses from sight for a cleaner look.
            Originally posted by wppracing View Post
            • HYDROJERRY
              • Jan 2010
              • 2709
              i vote you just use the factory rudder pickup and go inside the hull and put a Y-splitter inthe water tube so you can run one to the motor and one to the esc so they both get fresh cool water!!! Well thats what i plan on doing..
              • skyhighdiver
                • Jun 2011
                • 312
                But if you put a y in the line the water goes to least restriction so one side may flow great and the other gets very little.even 3 inches of line longer on one side makes great differance in flow.
                • HYDROJERRY
                  • Jan 2010
                  • 2709
                  Yeah but if you think about it theres alot of flow going threw there and also originaly the water flows from pickup to esc then worm to motor then wormer out the side of the hull so if it goes pickup to Y to esc first probly and then alittle slack from Y to the motor but cool water instead of worm from esc then wouldnt it seem beter,,,, well thats just my thoughts on it,, right now im waiting for my Y's to come in the mail and im going to try it maybe this weekend!!!!
                  • skyhighdiver
                    • Jun 2011
                    • 312
                    Let me know how this goes
                    Id be curious to know as Im just thinking water hose when i water lawn works as I described
                    • HYDROJERRY
                      • Jan 2010
                      • 2709
                      My MG runs super cool now but ive already done this on my Genesis and she was running super hot so i will run it this weekend and ill let you no what happens..
