LIPO cells
  • skyhighdiver
    • Jun 2011
    • 312
    LIPO cells
    So if I take 4 2c 7.2-volt lipo packs, parallel 2 each side of the boat and then series the 2 together this is still considered 4 cells, just longer run times. Is this correct or is this considered 8 cell any drawback to this versus 4c packs as I already have 8 2c packs
    Miss Geico (now white) Leopard 4074 2200kv motor T180 esc,x642 54.6 mph
    Miss Geico 2(now black and white)4074 2000kv motor, T180 esc m445 51.2 mph
    FAT PEOPLE ARE HARD TO KIDNAP
    • 7512
    I assume you meant 2S, not 2C.
    Otherwise you are correct as the overall voltage is 14.8 V. The only drawback is that you are going to have a lot of connections, each causing resistance and heat...in otherwords, more spots for potential failures.
    • Peacock8
      • Jun 2011
      • 97
      Why not parallel 2 4s packs?
      Ørjan.
        • 7512
        He stated he has a bunch of 2S packs already. He want to use what he has.
        • Peacock8
          • Jun 2011
          • 97
          Okay, I just tested my new 4s turnigy 45C-90C Those are insane :D I can recommend that setup.
          Ørjan.
