Miss Geico with 2200KV motor
  • davey
    • 178
    heres a look of a 4s set up ..running about 45 mph with 445,,,,strut angled to lower front end ,,but still has a little bounce...will a 3 blade help this any suggestions ..
  • davey
    • 178
    also same set up,,that ESC get 210 degrees when the motor and batts are 100 degrees ,,,what is up with the ESC
    • HYDROJERRY
      • Jan 2010
      • 2709
      Davey do you have the offset rudder???? It helped alot on mine with all factory electronics,,plus do you have the strut level with the ride pads if not set it on the table with the prop just hanging off the edge so the strut is sitting on the table also and adjust it so the hull sits flat and the strut is flat,, i hit something in the water with mine the other day and it nocked my strut angled up and when i ran it she backflipped then i noticed the strut!!!!
