2200 castle motor, what battery should i run?
  • tman
    • 123
    I have a 2200 castle motor with a 180 turnigy esc installed in my mg. I was told to get 6s batteries, is this right? I do have a 440 brass prop also. I went to another local shop today and was told I should only run 4s because the 6s ( 2 3s) would blow the motor, is this true????
  • Alexgar
    • Aug 2009
    • 3701
    I have a couple I wouldn't go over 5s
    • wilsta67
      • Feb 2011
      • 203
      you will blow your esc trust me been there done it.
      run it on 4s you will have ample power/speed and some to spare the 2200 castle revs like crazy.
      • wilsta67
        • Feb 2011
        • 203
        i have the same set up in my Geico.
        • tman
          • 123
          Ok, thanks
          • wilsta67
            • Feb 2011
            • 203
            These are the batteries I'm using. But I cut the 5.5 bullet conectors off them and put on traxxas style plugs I don't suggest you do that as it is a tricky thing to do.
            http://www.hobbyking.com/hobbyking/s...dProduct=14691
            • slowride
              • 91
              I tried 6s and blew the ESC...now I only use up to 5S even with the new T180
