What is your best speed?
  • Nealkot
    • 50
    Originally posted by CHIEFY_44 View Post
    i just used my eagle tree and top speed was 54mph
    leo 4074 2200kv
    m445
    4s2p 4000mha nano techs
    t-180
    Chiefy,
    I'm thinking of getting that motor to get me into the 50's on 4s (i already have the same esc and prop). My questions are:
    1- how are your temps using the 2200kv (batts., esc, motor)
    2- does the "tupperware" lid still fit with the 4074 installed?
    thanks,
    Neal
    • CHIEFY_44
      • Nov 2010
      • 254
      yes the tupperware lid still fits but i changed my flex shaft to a 187 and used a octura coupling because the standard one sheared off with me, if you go this way you may have to relieve the motor mount to fit the coupling i had to, temps were not to bad but i only ran the boat for about 3 mins the motor temp was around 140 cells were warm but not too bad caps were if i remember rightly were around 120 but to be honest i will not swear on these temps but possible in the next day or so i will go run it again and take alll the temps with my temp gun and forward them to you, the one thing about this motor it likes amps its very very hungry thats why i went 4s2p 4000, and only run for 4-5 mins max. my next change of motor will either be and neu 15151y or the castle version as they are more effiecent, ohh the other ting i did was remove the bec circuit off the esc and run a reciever pack to help the temps.
      Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
      • Nealkot
        • 50
        Chiefy,
        Thanks man, i think i might stick with the stock motor for now and try it on 5s for my next step. Only because i dont wanna stess out my batteries and one 3s pack will cost me alot less than 2 4s packs (to run parallel). Or, maybe ill just get a lower kv motor than the 2200. Thanks for your input,
        Neal
        • lyndon915
          • 38
          51.9 mph
          Etti 150 esc
          Feigao 11xl on 5s 5000 mah
          M545 s/p
          Kintec offset rudder
          • d.a.v.e
            • 230
            Fastest for now :) I have more props coming!
            41.1 mph
            SeaKing 180 ESC
            Turnigy 4c 1p 5000mah (two in boat only one hooked up)
            Stock motor
            Panther 230 (out of the box not balanced or sharpened)
