My Miss G.
  • BugFreak
    • May 2011
    • 15
    My Miss G.
    Hi all!
    Just got my MG, and I've run it a couple of times.
    I run 2x 7.4V 5400mah (35C) - but it feels like the "oomph" disapears quicker that I think it should.. to the point that it becomes boring to run.. but when I charge the lipo's, I get 3000 mah into them.. it should be power left to spare.. right?
    I run stock wiring, and the deans are getting warm, so is the wires...?
    Bragging pic..
  • JimClark
    • 5913
    get rid of the deans
    Billy Graham
    • BugFreak
      • May 2011
      • 15
      I'm about to.. Soldering as we speak.. Will the heat cause so much resistance that I'll notice it in this way?
      • Darin Jordan
        • 9446
        Yes... the 3.5's on the motor are even worse... They'll actually de-solder from the heat. 5.5's are a great upgrade here...
        Darin E. Jordan - Renton, WA
        • johnf
          • Dec 2009
          • 1086
          Nice pic! Out of curiousity, how long do you feel the "oomph" should last? Fast electric boats don't have long run times like RC cars.
          Catching Air!
          • BugFreak
            • May 2011
            • 15
            I haven't timed it.. but I start notice it after 5-6 passes..
            I've soldered som bullets on the batteryleads last night, and I'll change the ones on the esc/motor later today - will be back with report on how it goes..
            • BugFreak
              • May 2011
              • 15
              Bullets on the batteries, and hardwiring the esc/motor.. worked like a charm!
              Don't know if it's a fact - but it felt quicker as well :D
              • Darin Jordan
                • 9446
                It should be. Less resistance between the battery and the motor means more voltage, means more KV, means MORE RPM!
                Have FUN!!
                • BugFreak
                  • May 2011
                  • 15
                  Videoclip from the last dip..
                  I think it runs great now, but any suggestions reg setup are welcome..
                  • Peacock8
                    • Jun 2011
                    • 97
                    Nice! Hvor lang kjøretid har du på 2X5400mah?
                    Ørjan.
                    • maxmekker
                      • 466
                      nice run.
                      Where in Norway?
                      Care to share pic's of the strut/prop position.
                      Drammen rock City
                      • BugFreak
                        • May 2011
                        • 15
                        @Peacock8:
                        Etter 6 min kjøring, ladet jeg 3100mah på begge pakkene.. har ikke fått fatt i prog.kortet så har ikke lipo-cut.. så er veeeldig forsiktig..
                        @maxmekker:
                        - Hordaland, Bergen
                        - Pics of strut is in the works..
                        • Peacock8
                          • Jun 2011
                          • 97
                          Okei, her er det vel bare å investere i flere pakker for lengre kjøretid.
                          Ørjan.
                          • BugFreak
                            • May 2011
                            • 15
                            Feiago 9XL in Miss G.. Anyone?
                            • Stone
                              • May 2011
                              • 5
                              Too much restistance cause the heat, not the opposite
