4s (38.1mph) and 6s (54.7mph) video
  • maxmekker
    • 466
    Nice run, and no bounce to. 6s in fun, but I got to tame my MG first.
    Here is mine with the kintec rudder,and all sorts of lipo placements and strutt adjustments.
    I had a look at you're site, and will try the settings in the 'RC BOAT MODIFICATION SECTION' . I will try to se If I an copy those( eventhough I think I have been there when testing in the video) and se if that helps. Going to try with the 642 tonight.
    Drammen rock City
    • nycow
      • May 2011
      • 2
      Originally posted by wppracing View Post
      Loosen the strut bolt and set the boat on a table with the rudder hanging off it. The strut will now sit level with the hull.
      Ok that's mean that according my sketch, the red line and the green line are at same level, without angle between them ? ( to insist but i want to be sure to understand well )
      Thanks again !
      • BugFreak
        • May 2011
        • 15
        Thanks again !
        I put som weight on the back of the boat to hold it down, then adj. so there was app. the same angel. Tune from there according to the handling of the boat - hope this helps :)
        • d.a.v.e
          • Jan 2011
          • 230
          How much weight are you using in the back?
          • BugFreak
            • May 2011
            • 15
            Not much.. just to keep it flat to the table..
            you can hold it down with your arm as well, if you can reach the strut and adjust at the same time.. :)
            • d.a.v.e
              • Jan 2011
              • 230
              Guess I miss read it thought you were actually adding weight to the boat somehow
              • TheBoatbojo
                • 22
                Why are you using a separate 1600mah Receiver Pack in stead of BEC power?
                • tiqueman
                  • Jul 2009
                  • 5866
                  Less stress on the esc since he's running at max voltage (6S)
                  • d.a.v.e
                    • Jan 2011
                    • 230
                    Dumb question by why are folks using an additional battery pack instead of an external castle type BEC? Seems like it would be one less thing to worry about charging?
                    • maxmekker
                      • 466
                      nhaa, that 1600 hump last's forever. I put back about 400-500 mah after a week+ running.
                      Drammen rock City
