stock flex breaking, replacement and prevention
  • PDR447
    • Feb 2011
    • 92
    So I noticed that there are 3 strands of wire broken on my flex shaft right near the coupler. I'm running all stock on 4s with a prather 220 prop. So I doubt it was the prop load that broke it. I think where it happened was my strut gap was set to the manual's recommended 1mm in the beginning... ran probably 5-10 runs with that setup. That seems like the most likely cause right? Just trying to learn from this so it doesn't happen again.
    Now, for a replacement what does everyone recommend? Is there a compelling reason to go with kintec or OSE over stock? The aftermarket ones are almost twice the price of the OEM replacement.
  • dont slow down
    • Feb 2011
    • 125
    A wire drive would solve all those problems, require less maintenance, and probably cost about the same.
    Real men have shafts.
    • LiPo Power
      DJI Drone Advanced Pilot
      • 3678
      OSE replacement is great.
      Canada
      • PDR447
        • Feb 2011
        • 92
        but what's better about OSE vs stock? just trying to make an educated purchase.
        • toyotatruckin
          • Aug 2007
          • 110
          I sell shafts just haven't gotten around to the geico yet, BUT the difference would be with just about any aftermarket vs OEM is quality -plain and simple.
          OEM or "stock" shafts are mass produced with minimal quality control and in a lot of cases with the RTR shafts sub-par materials used to make them.
          Most guys making aftermarket shafts use good quality cable (mostly from octura) and do a 100% better job soldering them up taking time to make sure they are straight (or with-in acceptable tolerance)--what this comes down to is a better quality product that will last much longer and you should feel 100% safer putting your nice custom prop on a quality shaft.
