Best ESC for 4s or 5s
  • wppracing
    • 109
    What is the best ESC to use with a 5s set up and still allow you to us 4s
    Watercraft Performance & ATV
    wppracing.com
  • ron1950
    • 3082
    its a toss-up question.......prob best is the turnegy 180 for the money but there are several brands that make the same esc ose sells them of one brand or another also
    • Alexgar
      • Aug 2009
      • 3701
      T120 or aq star 120 unless you upgrade motor later than get a t180
      • wppracing
        • 109
        I have the Turnigy Marine 180A Brushless Boat ESC coming on Wednesday. What settings should I use ? How do you program it compared to the stock ESC/programmer.
        wppracing.com
        • pyroM!KE
          • 379
          UNLESS ITS A MONEY ISSUE I DONT EVEN KNOW WHY PEOPLE MESS WITH THE 120..oops i had cap lock on..Get the 180 and be done..More than likely someday you will upgrade the motor anyway..
          • Diesel6401
            Memento Vivere
            • 4391
            Space....
            Sometimes hard to fit t180s in certain hulls.
            Whatever esc you get, dis-able the bec when running 5s....
            - Diesel's Youtube
            - Diesel's Fleet
            • jac4412
              FE Addict
              • Jun 2010
              • 427
              Yea and 120s should be fine on 5s... I'm going to be running a 120 with the 1800kv outrunner and should be perfect on 5s. I'm going to get a 180 anyways but a 120 should be a ok.
              JAC4412 RC
              • Diesel6401
                Memento Vivere
                • 4391
                120 should be real nice on 5s with that outrunner. I am running a CC1800kv outrunner on 4s with the stock esc and a grim 42x55.
                - Diesel's Youtube
                - Diesel's Fleet
                • jac4412
                  FE Addict
                  • Jun 2010
                  • 427
                  Well ben (fightercat) just convinced me to screw it and go 6s on the 120... that'll really open it up... decrease the amps as well
                  JAC4412 RC
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    Increase in amps. More amp draw with increased RPM, spinning at over 40,000rpm there will be increase in amps with the system trying to maintain that RPM. If you do it. Prop low and conservative.
                    Me personally never a fan at running esc's at max voltage, but I play things safe.... There are people running those esc at max voltage with no issues, but some do have issues...
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • jac4412
                      FE Addict
                      • Jun 2010
                      • 427
                      Hmm... things to consider I guess. Heck maybe I'll try both out... doesn't matter anyways... USA warehouse is out of turnigys!
                      JAC4412 RC
                      • Alexgar
                        • Aug 2009
                        • 3701
                        I've had some amp issues with that prop it's pretty aggressive
                        • jac4412
                          FE Addict
                          • Jun 2010
                          • 427
                          alex you mean the grim? If I runn 5s the x642 should be pretty safe right? Or should I go smaller than the stock one
                          JAC4412 RC
                          • ron1950
                            • 3082
                            i just put the turnergy 180 in a pursuit mono running 2 4 cells in parrell and no temp prob at all...used a 42 mm or cm what ever size we all use and it was great moving up to a m445 soon and test.....
                            • wppracing
                              • 109
                              What other brand of ESC is good to use with 5s besides a Turnigy Marine 180A Brushless Boat ESC . Found out they are out of stock.
                              wppracing.com
