Miss Geico Lets see what this thing can do!
  • JPriami
    N4FOX
    • 1711
    #31
    • ron1950
      • 3082
      #32
      i smell video!!!!!! when is the premire?
        • 9481
        #33
        Originally posted by JPriami View Post
        Got my in hull pickups in tonight. I used 2 of the duals for this. I don't like how the singles don't move much water so I figure each dual Y'ed into one line each for 2 lines, will get better flow.
        I also took the stock cooling line hole and put a grommet in there with a aluminum plug. So now you pop the plug out and if there is any water in the boat you can drain it a little easier.
        awesome idea bro, great way to get the last bit of water out
        I'm doing that on my PT SS45
        • pyroM!KE
          • 379
          #34
          If your going to run 6s with that esc be sure to use a smaller prop..Mine runs warm on 5s with bec disabled with a x642..It runs about 100-105 in 50deg water..
          • jac4412
            FE Addict
            • Jun 2010
            • 427
            #35
            Mike at 100 degrees that's perfect. Remember a normal ESC like the T180 are running perfectly at 100... Higher end ESCs can get up to 130. Keep in mind that typically electronics run best slighty warm
            JAC4412 RC
            • pyroM!KE
              • 379
              #36
              True but Im talking about 5s..Hes talking about running 6s..I wouldnt do it..Thats just me though..With a esc like a 180a, I would rather run a higher kv on 4 or 5s than push the esc all the way with 6s..
              Just my 2 cents..
              • jac4412
                FE Addict
                • Jun 2010
                • 427
                #37
                Oh absolutely true I was just stating if you thought that 5s at 100 degrees was pushing it... it's optimal. "running perfectly".
                JAC4412 RC
                • JPriami
                  N4FOX
                  • 1711
                  #38
                  I see where your coming from on the pushing an esc to max. I feel the same way about maxing things. But I've done it with a t-180 b4. I've run a 4082 1500kv leopard and a t-180 in a 37" mono on 6s with a m445 m645 and. Even a x646/3. And it's been doing the job flawlessly and temps were good.
                  I would get a swordfish esc that can handle more lipo cells so I'm not maxing the esc, but I just havent broke down to buy one yet.
                  I have bought a data logger last week so it's in this boat. I'll be monitoring watts, amps, voltage, two temps esc and motor, throttle position, rpms, speed, and a few other things. So the goal is start small on prop. Record data. Review data. Prop up each time if all looks good.
                  • JPriami
                    N4FOX
                    • 1711
                    #39
                    Think I'm done at last. Other than dialing it in and running. Rainy and windy today so no dice.
                    • JPriami
                      N4FOX
                      • 1711
                      #40
                      Someone mentioned COG is about 9" As a good start. Is that from the back of the transom or the back of the sponsons?
                      • Rumdog
                        • 6667
                        #41
                        Looks good. Not gonna offset the rudder?
                        • Rumdog
                          • 6667
                          #42
                          I'd shorted up the motor leads on the esc too. She's packed tight, huh?
                          • JPriami
                            N4FOX
                            • 1711
                            #43
                            Yeah it's a sardine can lol. I'm going to wait on shorting wires. I have another motor to try if this one dosent work out.
                            Made a grease catch out of a medicine bottle lol. I got tired of cleaning then grease ring in my other boats so I figured this might work
                            • JPriami
                              N4FOX
                              • 1711
                              #44
                              Going to see how it goes before I look at offsetting rudder. I read diffrent things about it.
                              • Rumdog
                                • 6667
                                #45
                                The 1518? That thing is a beast! I ran it on 5s2p in my 31" Rico and was getting 60 with a x548!
