Miss Geico parallel wired
  • ekaser
    • 33
    I want to get a longer run time for my boat. If I wire two 4s 5000 mah in parallel to boost the amps will I get a longer run time? Will the stock motor and esc handle the current?
    Thanks for feedback from a newbie.
    "People do not quit playing because they grow old, they grow old because they quit playing"
    Oliver Wendall Holmes
  • Alexgar
    • Aug 2009
    • 3522
    should work great the only thing i would do is ditch the connectors and go with something bigger
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      thread moved
      • JackBlack26
        • May 2007
        • 903
        I get 10 minutes with 5000mah 20C packs and a Castle 1800kv outrunner(2650 shown in pictures) with a 42x55 prop. You should get a bit more run time with the stock motor. The batteries will barely fit. I completely rebuilt mine to make the battery installation and removal a breeze.
        • d.a.v.e
          • 222
          What kind of speeds do you get out of this set up & do your packs come back hot? I've been thinking about moving to this exact set up.
          • JackBlack26
            • May 2007
            • 903
            Packs stay cool. What was getting hot were the caps but since adding 3 more everything runs good. Only thing is that even with 10,000mah I only get 7-8 minutes of run time. It's definitely power hungry.
            • ekaser
              • 33
              Where can I learn about adding caps to the esc?
              Thanks, Ed
              • JackBlack26
                • May 2007
                • 903
                Search the "general questions" forum. There are plenty of threads on several ways of doing it. I don't have a link on hand, but I made a post about how I added mine. Maybe you can search my past posts to find it.
