OffshoreElectrics FE Boating Forums
RTR FE Boat Talk
ProBoat RTR Questions & Answers Board
ProBoat RTR Catamaran's
Proboat Miss Geico 29 BL Catamaran Q & A
Programming Module timing setting
wppracing
Mar 2011
03-24-2011, 08:24 AM
What is the difference between the 2 settings ? and which allows the best top speed?
Which on/off voltage setting should you use with lipo batteries ?
Thanks
Watercraft Performance & ATV
wppracing.com
dirty
Feb 2011
03-24-2011, 08:33 AM
i run mine on high voltage cutoff,and linear speed
wppracing
Mar 2011
03-24-2011, 09:39 AM
Which timing setting ? timing low or timing high ?
wppracing.com
wppracing
Mar 2011
03-24-2011, 10:20 AM
Just got a call back from a tech at horizon hobby and was told the boat can use either timing setting.
High will have increased performance and less run time and Low timing will have less performance and longer run time.
Also to use the high voltage cut off setting.
wppracing.com
