prop questions need help
  • bbosncali
    • 767
    What's the difference in an octura x645 and m645? Also how would either work on a stock mg and would I be able to use still with a 150esc and 2200 lepard motor? Thanks for the help
    miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
  • Diesel6401
    Memento Vivere
    • 4391
    m645 is detongued. it's a good bit of pitch. A m445 would be a better choice for either motor IMHO.
    - Diesel's Youtube
    - Diesel's Fleet
    • bbosncali
      • 767
      Would it be a better prop with the upgrade? My biggest problem is I want to upgrade my prop I ordered a prather 220 but I. Have no clue on how to balance it. I want to buy one already blanced and the only one available from ose is a m645. I was gonna have chuck do one for me but he's atleast 2 weeks out
      • Diesel6401
        Memento Vivere
        • 4391
        Is this for 4s or 5s on the stock motor?
        Reason being you can run a m445 stock on 4s and do fine, but a m445 on 5s will blow the stock esc. Not sure how that 150amp esc would do. I assume it's a suppo, may work ok though. A grim 42x55 is a GREAT all around prop for the MG on 4s and 5s on the stock power also a x642 is a choice as well.
        Stock motor: (4s)
        x442
        x642
        grim 42x55
        m445
        Stock motor: (5s)
        x440
        m640
        x442
        x642
        grim 42x55
        x440/3
        grim 40x52/3
        Leopard 2200:
        x440
        m640
        x442
        x642
        s215
        s220
        x445
        m445
        grim 42x55
        The CF series props can work until you get your other props S&B, they have the same pitch as the Octura x4 series props:
        Stock 4s:
        CF42
        CF45
        Stock 5s:
        CF40
        CF42
        Leopard:
        CF45
        - Diesel's Youtube
        - Diesel's Fleet
        • bbosncali
          • 767
          Thanks for the help found someone who has one already balanced for a good price
          • bbosncali
            • 767
            642 that is... from what I read seems to be the best starter prop. Do you notice a big difference over stock with that prop
            • boaterkid333
              • Dec 2010
              • 25
              A M445 has a bigger radius with less pitch then the X642? Is it faster on stock setup?
              • Shaun78
                • Feb 2011
                • 419
                Hey Bos, I thought you said u balanced the 220?
                Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
                (63.7 MPH) Traxxas Spartan (same setup)
                • bbosncali
                  • 767
                  I did but I'm still going with the 642
                  • PIGSTI13
                    • 7
                    Hey Diesel,
                    Would the props you listed for for the Leopard 2200 work for the CC 1515 2200KV? Thanks.
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      Originally posted by PIGSTI13 View Post
                      Hey Diesel,
                      they sure would... I would say a grim 42x55 and the m445 would be the top choices... The motor can swing a bigger prop then that, but any bigger I think the hull my not like...
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • PIGSTI13
                        • 7
                        I will try both when we lose our ice. Thank you for the suggestions.
