has anyone ran one in saltwater for any period of time and is there anything i can spray on gear and electrics it will be getting after each day of running and flushed out with freshwater
miss geico in saltwater
I ran mine in the San Diego bay before. Just rinsed it out and everything was fine. Only prep I did was wax the hull so the salt wouldn't dry and stick to the paint. Just make sure you seal it good in case it flips.
i ran mine at the san diego model yacht pond and didnt rinse it out till i got home like 4 hours later and the cooling outlet on the side of the boat already started to rust. if u run it in salt water.. rinse it immediately afterwards... good!!!
I live in Florida and run mine in saltwater regularly. You just have to stay on top of preventative maintenance. Corrosion X is a must before and after. Also after my run when cleaning with fresh water i use something called Salt Away. I mix some up, put it in a spray bottle and then you can spray it in the water outlet till you see it coming out the pickup in the rudder, then rinse with fresh water and spray everything metal with corrosion X.
Running in saltwater can be fun especially if the water gets rough, it makes for a cool site almost like a real mystic offshore.
Radio shack they sell an anti corosion spray works the same as corrosion xOriginally posted by Skholar View PostI can't find corrosion X where I live....will WD-40 do the same thing? Silicone spray is easy to get..
Sorry for the newb question, but where do you apply your anti-corrosion spray of choice??miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
Saw it on their website....all the radio shack stores in my area have been taken over by The Source and they no longer carry that product. Can anyone suggest a product that is readily available in Canada?Originally posted by bbosncali View PostRadio shack they sell an anti corosion spray works the same as corrosion x
I'd think wd40 could work as long as your cleaning all the saltwater off and doing it right when your done running. As for were to apply it, itgoes on anything metal. While your cleaning do not forget to flush out the water cooling hoses and jacket, u can accomplish that easy enough by taking a mouth full of fresh water and blowing it in the outlet, and repeat a few times. If u done you will get a rusty motor!Originally posted by Skholar View PostI can't find corrosion X where I live....will WD-40 do the same thing? Silicone spray is easy to get..
