MG stock Flexshaft prop nut.
  • Diesel6401
    Memento Vivere
    • 4391
    Not sure if anyone has had a problem with finding the right size prop nut, but I did. I have a reverse and standard flexshaft from the MG that I am using in a twin. The flexcables did not come with prop nuts, so I dug in my stash pulled out 2 10-32 nuts like most of my other cables use and they did not fit. So I used a thread gauge and found they are metric m5-.8 nuts. You can pick a 4 pack up at Lowes for $.68, just though I would share that.
    These worked for me: http://www.lowes.com/pd_138357-37672...&storeId=10151
    - Diesel's Youtube
    - Diesel's Fleet
  • GeoVW72
    • Jun 2010
    • 258
    really
    bought a new flex shaft and it even had the prop on it.
    Octura brass bullet nuts also work
    Team Boca Bearings
    S&G Design
    • Darin Jordan
      • 9446
      That is weird... My replacement shafts came with a prop as well (plastic).
      I keep trying to specify to the manufacturers that I want 10-32 sized threads... Guess I should be happy that they at least get the 3/16" prop-shaft part correct!
      I'll keep working on them for future products. Trying to get all of these US market boats to be standard sizes in these areas.
      Darin E. Jordan - Renton, WA
      • Diesel6401
        Memento Vivere
        • 4391
        Originally posted by GeoVW72 View Post
        really
        What shaft did you buy? If it is the stocker http://www.horizonhobby.com/Products...#quickOverview that bullet nut will not work
        When they sent me the replacement cable for the reverse mix up it did not come with anything besides the flexcable/shaft. No drive dog, no nut. Just the assembled flexcable. I was shocked it wasn't 10/32.
        - Diesel's Youtube
        - Diesel's Fleet
        • GeoVW72
          • Jun 2010
          • 258
          that was the ose cable, my bad.
          Darin, I thought you were making your own so the rest of us could get them
          I don't think they'll be running out anytime soon
          Team Boca Bearings
          S&G Design
