Killed my ESC?
  • Akoni
    • Sep 2009
    • 41
    Killed my ESC?
    So I used the porboat programming card on my MG just now and it will no longer arm after i turn it on. Is there a combination of settings that might cause this?
    Was trying to set:
    Lipo
    High cutoff
    Slowdown
    Brake off
    Timing low
    Throttle linear
    Would I need to rebind it somehow?
  • ron1950
    • 3024
    hook up the batterys....hook up the card....(set the card) turn on power......it will beep once.....now turn off switch....unhook batterys......done......now when u start it up again ready to run ...it will beep twice i think 5 times and all is well lol good luck...
    • Akoni
      • Sep 2009
      • 41
      Yup...unhooking the battery did it...didn't have directions but found it by accident. Thanks. When you change to lipo battery type, what does that do to the LVC settings (what's the voltage for high vs low cutoff) ?
      • ron1950
        • 3024
        not sure what the figures are for high cutoff....but thats what i use...high cut off linear throtal and lipos etc.....darin the disigner of this boat has a thread here somewhere about here that has your info....and what he recomends also
        • JackBlack26
          • May 2007
          • 903
          I just did he exact same thing. I programmed it then though it was dead until I disconnected the battery and reconnected it with the ESC on. It beeped and now its working....sad thing is I had the instructions on my lap
          However, I cant get the reciever to bind with my DX3R. I unbound it and bound it to the included transmitter just fine but for some reason it doesnt like my DX3R. I wonder if the marine ESC only works with the 3S and not the 3R
          Now its off to the lake later this evening
          • ron1950
            • 3024
            mr3000 will not bind to the dx3r it only binds with the dx3s and below...ones that have the marine sticker on the back.....u need to use the tx that came with the geigo or get a 3s, 3e or dx2 or 3
            • JackBlack26
              • May 2007
              • 903
              Thanks Ron. I'll just stick with the stock radio. I would hate to get my DX3R wet anyways
              Worst case, I also have an inexpensive Tactic 2.4 system like Aquacraft is using now that I can uses if I get the transmitter wet.
              • ron1950
                • 3024
                u planing to go swimming? with the tx? lol....the proboat tx is inexpencive but a pretty good radio actually......
                • JackBlack26
                  • May 2007
                  • 903
                  No. But I'm known to be pretty darn clumsy.......
